[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
Re: [WIP][ROM]COLD AS ICE-CM9 Sprint LS670 5/6 ZVD basesband Alph
I kinda like Sense? (and anyway, the opinions of tech websites don't matter, thekraven's and the cyanogenmod team's do)
Yeah I kind of think it's neat...swiping them up to get rid of them is pretty cool too haha.
Exactly, personally, I like sense better than the stock recent apps.
Sent from my LS-LS670 using Android Central Forums
What are the chances of getting the music player from cm7.2 to cm9? I really liked the transparency option for the widgets
Who will guard the guards?
When I flash alpha 10 everything's all yellow and when I flash ur cm7 the phone goes to sleep but when I wake it up it only comes with a gray backlit screen. My phone hates cm for some reason but it loves drew's cm7 weird huh
Sent from futuristic optimus s
Don't flash any kernels on both.
The more I play with this, the more I love cm9. Sounds corny I know but google REALLY stepped it up with this. Kraven you tha man! Oh Apollo is NICE AND CLEAN.
haven't tested USB tethering in a11 but my battery was dead before noon today unplugged at 830 could be the fact I installed all apps over 3g charges much quicker than prior cm9s over all seems quicker will test more tonight.
also I really like the sense app switcher
Edit: Apollo is awesome! only complaint with it is when you download a VM from Google VM it doesn't play when u click on it have to go find it in apollo.
search key --> recent apps key zip works?
You will need to delete the android.policy.jar file in that zip, then flash with signature off. Or just push the keypad files.
whoops. Thanks.
attachment.php
And this, kids, is why you listen to Kraven.
Reactions: aaronrw
Is titanium backup going super slow for anyone, since the last couple TIbu updates? I suspect my oEM sdcard is finally going out.
Camcorder force closes still. But it worked as far as recording, but dies upon shut down. Not sure about titanium I let Google install my apps. I'm pretty minimal on my apps so it's easy
Sent from my LS-LS670 using Tapatalk 2
Nope, zippy as a stuck pig (and I don't have a class ten either, this is a costco-bought sd)
Speaking of ROM reviewing.......I'm starting to like the new kid on the block....
attachment.php
Test hidden wifi if you can. I went back to some old ramdisk changes to try to fix the wifi errors on a first clean boot.
not sure why but opera mobile will random close sometimes since a10f. still happens on a11. starts out as fc's non stop reboot helps for awhile then just starts closing w/o fc
From what i remember, you need to use a older version like 11.1
Reactions: mkfryan
When will YouTube HD be fixed and Bluetooth in calls
Download Apollo apk - dl.dropbox.com/u/2301775/Apollo.apk
janvi33
