[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
Re: [WIP][ROM]COLD AS ICE-CM9 Sprint LS670 5/6 ZVD basesband Alph
@thekraven: on a11 when coming off wifi at work tonight had to do toggle dance 3 times to get 3g working.
im back on cm7 for other reasons, but one of my biggest annoyances was just that, assuming you mean the recent apps list? i prefer to see the several small icons in gb than 2 big ones you have to scroll through in ics.
In Gingerbread, you can't kill the app with the recent apps menu. In ICS, swiping kills the app, rendering task killers useless.
Sent from my LS670 using Android Central Forums
YouTube HQ may never be fixed as our phones don't have omx libs compiled for our processors and prob never will meaning HD hardware acceleration is a no go.
Bluetooth incall audio will be fixed before apple drops all of its lawsuits.
Sent from my LS-LS670 using Android Central Forums
so, what is actually needed for Bluetooth calls to work?? I see that it is working in a few ics builds for different phones. but for the majority, its not?
so what are we missing??
I've had surface dithering DISABLED and I've noticed some improvement when entering the app drawer. Just an fyi for you CAI people.
Sent from my VM670 using Tapatalk 2
Just disabled surface dithering and found you to be quite correct. Also, scrolling in Dolphin Browser is significantly improved. Thanks for the tip.
I can confirm this, it runs smoother. Thanks!
Sent from my VM670 using Android Central Forums
Where can you disable this ?
Edit** i found it and yes its way smoother
wifi not working on alpha 10g what am i doing wrong
I want a ETA on the ETA's and this time im shooting for kittens!
Nah just kidding.......
im curious I know we dont have front camera but will we be able to use the facial recognition security features of ICS?
new themeable elements work correctly :D
some stuff i still can't get to theme, mainly the Mms.apk.....it's probably themeable, i'm just missing something....they have changed a lot ....sheesh
Has anyone been able to get the built-in encryption working?
This is probably why Netflix doesn't work then. I just confirmed that I get audio but no video.
bagaiamana
