[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
Re: [WIP][ROM]COLD AS ICE-CM9 Sprint LS670 6/3 ZVD basesband Alph
Just wanted to thank thekraven for restoring harmony to my life and home. My wife was adamant about having ICS on her Optimus V after seeing it on mine. She was running a different distribution and was not very happy with the stability, but after flashing 11D to her phone with the VM fix, she's back to being the woman I married. Thanks again.
I didnt realize I could use this on the Optimus V. I am in the same boat as you using a Opt S myself and my wife using an Opt V. Where can I get this VM fix?
Kraven,
Things are looking great! Not asking for an ETA on anything (11D will do for now!) but I for see a beta release in your future!
Sent from my LG-LS670 using Android Central Forums
MAIN SCREEN TURN ON issue remains in 11D. Multiple keypresses (home, menu, power) often required to turn display back on & get to lockscreen. Seems to happen more if a process/app is running (like Navigation, Google Music/Slacker Radio), as if the call to bring the display back just isn't getting priority.
Display not returning during calls when phone/proximity sensor moves away from my head is darned frustrating, too, as having to press "home" key adds an extra step to ending calls, and pressing power tends to end my calls (even when option is turned off), making it so I can't really go through touch-tone automated menus.
Whats the fastest launcher for ICS on the Opt S? On theKraven's CM 7.2 I was using Launcher Pro and it was very fast.
I'm using Apex. Fast and smooth and very customizable.
Sent from my ZombieICS-VM670 using Xparent Blue Tapatalk 2
Reactions: pspOPT
Kraven: 11D IS AMAZING! although I did have the screen lag issue while copying files using ES File Explorer (not much different though from normal). Overall it's pretty snappy, had a small lag issue with Google music yesterday even with the processor clocked up a little but haven't seen it since I switched back to SavagedZen.
Does changing lcd density bork phone app for anyone else? If so has anyone figured out a workaround? I havent noticed this because I have not been using my phone for calling in a while but now I am again and when I place a phone call it FCs I can still talk because phone app runs in the background but there is no way to end calls. Thanks in advance guys
Getting weird display artifacts and lag when I select an item in the notification screen. Chunks of the notification and the new app opening as well as home screen. Looks like streaming video breakup. On 11d clean install. Flashed the qcomm drivers with boottest9 then kernel 15 to see if that helps - it doesn't.
LG-LS670 w thekraven ICS ROM & Tapatalk 2
Trebuchet has been working well for me, Apex gives a few more options and runs great too.
Reactions: pspOPT
You mentioned before you haven't clean flashed this, have you done it yet? I can't reproduce any of those bugs you mentioned.
Oh noes! The issue with public wifi networks is back! It maintains the connection for half a minute then nothing.
Could be the cause of vsync off in the kernel. But I've had that off in all my test kernels. I wouldn't use any display patches prior to 11d. I resynced just before that build. Try the conservative governor and report back. In other phones, that fixes some artifacts
Reactions: Pkt_Lnt
Kraven,
Probably stay in alpha till bluetooth, audio routing, and clock sync bugs are gone. Or if I burn out... And that's not too far away
I haven't had luck getting flash to work. Is there anyway to get it working? I have the same apk I've been using for over a year now.
But if you burn out then we will have no ics and I love icecreamsandwiches they are dillicios ehh can't spell
Sent from my LS670 using Android Central Forums
What flash v is it I had 11 running fine haven't had a good unuf internet connection to dl 11d though so I am still on 10g
Anything we can do to help make that farther away/less likely to happen?
99% of the posts are not about testing CAI. Burns me out, probably worse for thekraven wading through tons of irrelevant posts.
Brabian
