[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
Re: [ROM]COLD AS ICE-CM9 Sprint LS670 6/20 ZVD basesband Alpha15
Is anyone able to get data2ext working on this ROM anymore? If so, what are you using? Also, is there a way that the Sense multitasking (recent apps) can be changed back to stock ICS? Any help is appreciated.
I dont know about data2ext but I use Mounts2SD I dont know if that's the same thing but I use it and it works for me
XDA Thread
It has a graphical installer with customizable options with the ability to move the \data to ext\data
Dang, homework! ;)
I'll search to find out what that really means.
So the b1p3 build.prop pushed to CAI makes 3g work really well, but breaks deep sleep.
Speaking of break. The assert values in a15e don't work in drew's Cannibal 1.1
Here is what they should be.
Code:
ro.product.device: thunderc_LS670
ro.build.product: thunderc_LS670
http://forums.androidcentral.com/lg...pen-touch-v1-1-huge-update-5.html#post1855510
It's that "pure IHO source"thing again / stiill. :D
15E is for xionia only. I couldn't build due to the server was down. I see now what i should have done to fix the updater-script. It will be fixed in future builds.
Code:
assert(getprop("ro.product.device") == "thunderc" || getprop("ro.build.product") == "thunderc" ||
       getprop("ro.product.device") == "LS670" || getprop("ro.build.product") == "LS670" ||
       getprop("ro.product.device") == "thunderc_LS670" || getprop("ro.build.product") == "thunderc_LS670");
Ok, homework done, I understand.
Found this.
Android Tips for Rooted Phones
change
Code:
ro.ril.hsxpa=1
ro.ril.gprsclass=10
to
Code:
ro.ril.hsxpa=2
ro.ril.gprsclass=12
and I see you have this.
Code:
# V6 SuperCharger settings
ro.ril.hsxpa=3
ro.ril.gprsclass=12
ro.ril.hep=1
So if @tdm settings match the first code box, is that why I get better data? Logic tells me otherwise, but I am in way over my head here. Guess I can try to change them back and see.
Code:
oh ok, that's probably why i couldn't get it to install...i switched to cannibal.....
Kraven you should put recent apps like the quattrimus ice has it ...it has a better feel to it
Sent from my LG-LS670 using Android Central Forums
I updated to 15D and found that, while it says I am not roaming, I am still stuck at 1x speeds.. Did I do something wrong..?
No, read back up a ways, I have been having that issue too, look at the build prop exchanges between thekraven and myself. Is your data signal strong normally, or marginal like mine?
Still doing the adb pull, read, research, tweak, push, test, grumble routine.
Why ? If you don't mind me asking
I wouldn't question why a dev chooses to do something...it's his work, he can do what he wants, a lot of people have requested it but it is clear that he prefers how he has it. Quattrimus works just fine if you want the stock recent app list.
Reactions: mkfryan
It will vary in signal strength. For example, being in town I will have full strength but only 1x, and when I went to the mountains it declined. I'll read the previous conversation to update myself of the situation.
I know, I was a cell tech for 15 years. I also saw a cell tower on the building above me, and RF Signal Tracker https://forums.androidcentral.com/e....utility.rfsignaltrackereclair&token=XNzFyQNE gave me all the RF data. Still I had 1x signal. I live in the mountains near the ocean in CA, I understand RF signal propagation. But in known strong areas, no 3g, only 1x.
Reactions: Sparain
Thank you theKraven and the other devs for all your hard work on this rom; I never expected my Optimus S to work so well. I was perfectly satisfied with our CM7.2.
THANKS for doing the same with CM9/ICS!
I do have a few questions though;
1. It seems the speaker phone is still barely functional/audible. I am running your CM9 Alpha11D and am about to apply the Alpha15 with the vsync off kernel since I prefer performance to quality. Am I the only one having that issue, or is that something you're working on?
2. on the cyanogen mod 7.2 settings we used to have an option to enable moving of any non-system apps to external media, and a setting to default new apps to install on the external sd. I cannot seem to find it in ICS/CM9, and I dont want all apps to SD ext either.
3. I have to report that I was also having the Google voice issue with not receiving messages until I used my phone; that is until I added the widget on the home screen. It seems the system is killing the task for google voice, but if you have the setting turned on to lock homescreen in memory, google voice/widget stays on as well. My voicemail messages have been going into my call log from google voice; is that an ICS feature?
4. What file system do you recommend be used? I have a Samsung moment moded with CM7 from sdx-developers that we were playing with ext2-ext3-ext4 instead of rfs and it was a noticeable boost, but you had to be running a kernel that supports it. Is that something that is supported with this rom/kernel?
5. Feature Request: could you fix or replace the built-in voice with the one from the market on your future releases? maybe when all is fixed and your donation box is full... What is it that is missing for the built in app to work, the audio library files? I understood there was a huge property in terms of rom space because the language files had to be on the phone for offline use with ICS. There was talk of the Samsung Galaxy SIII voice app being a feature we could work into roms with the apk and a specific file to go into the system directory...perhaps that is viable? I'm asking too much already, sorry. also, with regards to the voice key doing recent apps, It's a great option, dont change it!
6. Feature Request: Offline charging like you set in your CM7.2 rom would be great!
Keep up the GREAT work, and thank again for continuing on this project!
Quadrant and NeoCore scores have never been higher 56fps, THANKS!
Code:
Kraven none of the recoveries work with 15D for VM, they all give me an error similar to you code. Is there something I can do in the meantime while waiting for the next build?
Use cot 1.0.8
Thanks rebel, that is not available in the post for that recovery the only option is to download the latest 1.1 which I already tried, did a quick google research and could not find it.
kimswid48
