[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
Re: [ROM]COLD AS ICE-CM9 Sprint LS670 6/20 ZVD basesband Alpha15
So, I have COT by Drew.. haven't updated to LATEST update, but I have it...
What is the latest version?
If 10E is for Xionia, will it flash in COT?
COT 1.1 has a flashable zip install, quick and easy. CAI get 15d for COT or 15e for Xionia. They are the same except asserts in the updated script.
LG-LS670 w thekraven ICS ROM & Tapatalk
Kraven none of the recoveries work with 15D for VM, they all give me an error similar to you code. Is there something I can do in the meantime while waiting for the next build?
Did you try 15e? They are the same except the script asserts. thekraven built 15e for Xionia, but it might work for you.
Ok, an update on my build.prop swap adventures.
If I just pull the build.prop from CAI, and do nothing to it, push it back, and adb reboot, I can keep 3g signal going to weaker zones, to a point of course. Now I get 3g in places where I can only get 1x until I pull / push. Once I do that when it is a problem, say on a restore, then reboots after are fine. Voodoo, but I am happy. :confused: :eek:
Also, testing kernels.
15 is smoother, more fluid in the screen movements, but not as quick on app or launcher screen changes, and seems to lag every so often.
16 is a little slower, drags slightly, on screen movements and launcher screen changes, but the entire system runs quicker and snappier.
YMMV
I've been using this Alpha15D all day today.
What I have to report is as follows.
Sometimes I get a cannot sign in error. Both for the Play Store as well as
Email accounts. NOTE: A reboot will usually fix this (sometimes) Or I have to remove an account and re-add the same account again.
Sometimes I get "app not installed" when I click on the Play Store. It happens most when I click the small icon on top of the drawer page. Not so much on the regular Play Store icon.
NOTE: A reboot will usually fix this. Or I can re-flash gapps. Clearing app data doesn't have much effect on this problem.
I also got a random reboot when I changed the wallpaper the first time. Haven't got it since.
Bluetooth is iffy, some devices find it up others do not. Some devices get found up others do not.
When I ran through About Phone. It still shows my old phone number
I don't quite know how to get that updated.
Stuff from before includes the panorama mode not working, Speaker phone not working.
GOOD THINGS:
Custom shortcuts on the lock screen work great.
3g works great for me.
WiFi works great for me.
Sync works great.
Cannibal Recovery works great for me.
Overclocking works great. I'm at 787max 320min
ICS MDPI Themes work great.
Battery life has also been really good.
WISHLIST:
RenderFX widgets (I love those things)
Change Carrier Text on Notification area
Take over the world.
GOOD THINGS:
Sync works great.
WISHLIST:
Any issues with your phone entering Deep Sleep reliably?
I posted an image above of CPUSpy showing that it is going to deep sleep, and continues to do so.
Here it is, I thought I deleted it.
@thekraven
Found a typo, missing letter in the build.prop
Code:
#Dynamite tweaks
# Increase battery and longer standby time with deeper sleep
m.sleep_mode=1
ro.ril.disable.power.collapse=0
missing the "p" in pm.sleep_mode=1
Searching build.prop tweaks
Code:
ro.ril.disable.power.collapse=1
pm.sleep_mode=1
I changed the first one to =1 and will see what happens tomorrow. Maybe help the deep sleep situation.
I found other things, get excited, you already have them. I should know better than to challenge someone far better and more experienced.
I haven't had any problems. I don't even get clock lag
Sent from my LG-LS670 using Android Central Forums
Thekraven, I am running quattramius b1pre3 and I just noticed that offline charging works.... sorta. I just plugged it in, expecting that it would just boot, but i got the standard charging animations, but when i held down the power button to boot, it just showed it LG logo then rebooted back into charging. I know know how tdm did it, but if you could some how implement it, that would so awesome! Thanks again for all your hard work!
@thekraven
Code:
#Dynamite tweaks
m.sleep_mode=1
Code:
pm.sleep_mode=1
I saw it and changed to pm, im running 11d with test15 kernel, it must be like that in all the builds. I tried 15d/e thanks kraven, i think ill stick to 11d absolutely smooth.
its working
Reactions: thekraven
@thekraven
Code:
pm.sleep_mode=1
I'll test with this too. just pulled/pushed it, now it's got pm.sleep_mode=1 as well as ro.ril.disable.power.collapse=1.
In the words of GLaDOS, "Continue testing."
I'm having MMS issues with 15E. I've tried Messaging and Handcent, and I'm unable to send MMS having a significant delay with sending pictures when they send at all. Receiving is not an issue, just sending. I've seen murmurs about issues in past builds, but I figured they were fixed. I've tried to dirty flash the build over itself to no avail. Suggestions?
Im running 11d with test15 kernel and everything's working no probs, i had the same issues you're having with 15d/e so i switched back
kimswid48
