[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
Re: [ROM]COLD AS ICE-CM9 Sprint LS670 6/26 ZVD basesband Alpha16
Well according to Titanium backup...my System Rom only has 10.6 MB free. Know of a way to free that space up?
How much free space for your /cache partition? how about /data?
any one know if wiresless tether works? foxfi doesnt work on new build or tethering at all for that matter
I was using wireless tether, I googled cm9 wireless tether apk. Think it was thru xda. Download and install thru file explorer or whatever its called.lol. edit search the threads...its all in here.
I was also getting the 3g data lockup issue after dirty flashing from 15 to 16e and believe I found the cause as after doing this the issue never reappeared. I also wasn't getting any notification for texts due to this issue, and this took care of that as well. Hope this helps...
Here's the situation: old mms user data from the previous rom/version inside your messaging threads, especially with pictures was causing a conflict. You send a pic through mms and it gets stuck on sending, after which your 3g data locks up, but not wifi data. A reboot would be the only way to get 3g data back.
The solution; simple. All you have to do is open the messaging app and delete all threads. Done.
Also, to those of you getting the "package file is invalid" or similar issues when downloading large apps from the market, I found that uninstalling it, then immediately installing the new version right from the market took care of the issue. Some of my app downloads would randomly say insufficient space even though I've got 83mb left in ROM space, and uninstall/reinstall update version also took care of that.
Anyone know what the benefit of the 16e zip align fix would be? I'm assuming just a more compacted rom....is that right?
Reactions: PatrickAkridge
I've had good luck using Barnacle WiFi Tether but only without encryption enabled.
barnacle works for me too, but only with laptops, consoles cant seem to find the hotspot ( I tried on a wii and ps3)
btw, is 16F coming soon?
thanks guys! :-)
thanks guys! :-)
http://forums.androidcentral.com/lg...0-6-26-zvd-basesband-alpha16.html#post1612811
CM9 Alpha build for Sprint optimus S
"COLD AS ICE"
ZVD only
These are public test builds, so expect bugs. There won't be too much to changelogs till Beta. Test away and report bugs and what works for you. ETA's does kill puppies. So don't.
this one seems to work really well, but you need to load it a couple of times and switch the mode to the second one available. I was able to share my 3g with my Android tablet and laptop. My blackberry wouldnt find it, but I'm ok with that. There is an old version of the wifi tether app that works excellent, but it got pulled from the market, if I can post the .apk I will put it here.
https://forums.androidcentral.com/e...googlecode.android.wifi.tether&token=NMWh-ehv
Has anyone got a sprint voicemail apk that works with this rom? I do not like the google voicemail setup =/
I'm getting 3g data from foxfi... Via blueDUN.... dont forget to install pdanet on your tablet and then you canconnect via bluetooth
Sent from my GT-P3113 using Android Central Forums
@thekraven...ok so if youtube HQ works on the galaxy ace, which is the SAME chipset as the Optimus S, Qualcomm MSM7227 (Optimus) vs. Qualcomm MSM7227 (T) - Galaxy Ace which is meant to deal with the faster CPU on the galaxy ace (800 mhz).
Does this mean that HW decoding may indeed be possible for the Optimus S, for the likes of HD YouTube and other video?
Reactions: jcruckus
You need drivers. There will probably never be ICS OptiS specific hardware drivers. YouTube HQ works just fine on my wife's phone, running DanteRom. Flash 10.2 works wonderful, under Gingerbread. If you must have flash and/or hardware acceleration, you would probably be better off on a different ROM.
Right. If drivers exist for the same chip set but on a different but very similar device, in theory porting the drivers should be possible.
Sent from my LG-LS670 using Android Central Forums
"I want to move to theory. Everything works in theory."
John Cash (Of IdSoftware fame)
:D
Just to clear the air here.... The Galaxy Ace and the OPtimus S don't share the same chipset.
There are 35 devices that use the MSM7627 chipset. Some of them use Windows Mobile or PalmOS. One uses RIM Blackberry OS.
We have discovered that there are variances in the chipset between Optimus S's
What can work wonderfully on one OptiS can very well screw up another OptiS.
Optimus S- Qualcomm MSM7627
Galaxy Ace- Qualcomm MSM7227T
Reactions: CardcaptorRLH85
My mistake. Extremely similar chip sets same armv6 processor and same adreno 200 gpu. Just saying it may be possible. I know its improbable
kimswid48
