I'm home mama
Looking for good cm9 or cm7 themes??? visit this site for good themes. http://forum.digitalhouseoftreats.com/
Conker1r:
I'm not having the brightness issue, but then again I dont have the auto brightness setting available in display settings: never have since this rom came out, so I'm not sure what made it show up on yours... If anything, go into the display settings and disable the auto brightness, then disable and re-enable the status bar brightness mod. you might have to boot to recovery, then go into advanced - wipe dalvik cache to get it to re-read the config, or just do a dirty reflash of the latest version of the rom without wiping out your system or data. If that doesn't work, wipe/format system, then make sure everything you have is mounted under "mounts and storage" and reflash the rom. Post back and let us know if that take care of it...
This rom is not built for the vm, but some fine it works. 16e is the newest. have you tried quattrimus by tdm in the vm forums here? Basically the same rom, with very sight differences. Sorry too lazy to find the link for you, you understand.![]()
Lol yeah I know just was wondering and wanted to try out that's allthanks for the heads up
The Optimus does not have the photosensor for brightness.
Seeing auto in setting is just a leftover of the CM9 builds. It does not matter, but does not do anything.
I was wondering about this. I use Google maps all day long, and it switches into night mode every time I enter a tunnel. I wasn't sure if it "knew" I was in a tunnel or it "saw" that I was in a tunnel.
15f and the VM fix work great for us OV users. At least most of us...I've been playing with AOKP for a while, but my battery life hasn't been as good as this. I saved a copy if its not all still in the OP , I didn't check before posting. Let me know if you need anything.
Work with zvj?
Sent from my LS670 using Android Central Forums
kraven, I'm on build jun 25, 2012. And my google music is not streaming.
as most of my songs are on gmusic. What should i do to fix it? uninstall and reinstall or flash the newer version
