[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
Wait, so if I flash Zhj then flash CAI or any other rom that is zhd, does that mean the radio would use no battery what so ever?
Sent from my LG-LS670 using Android Central Forums
The radio is still on regardless of version or if you have service.
I have an OV that I use for a voip phone. I turn off the radio from the phone testing screen: dial *#*#4636#*#*. You need to do this after every reboot.
Reactions: kylemaguire
Everytime I try booting I get the loading screen (blue matrix deal) and that's as far as I get
Sent from my LS670 using Android Central Forums
There is a free widget named Dazzle that will do it with one touch, in the Play Store.
- via Kindle Fire w twa_priv ICS / CM9 linaro based on SG7 & Hashcode 3.0 kernel - Tapatalk 2
Reactions: tdm
I also used the quattrimus version and colors are inverted and screwwy, plus it keeps rebooting
Re: [ROM]COLD AS ICE-CM9 Sprint LS670 6/26 ZVD basesband Alpha16
Flashing some add on kernel will do that, use only the one in the ROM or the two in the OP, but the one included is newer.
I just went into that screen and saw that radio was off because I was on airplane mode. Thanks I always though that the radio was constantly on.
So..found something interesting. I was able to capture the 1980 date ppl were talking about a while back for myself.
I had planned on testing quatt for a few and wanted to nand. Something at that time stopped working so I did a battery pull before entering recovery. An being from a PC background, I also held the power button down for 10 sec to clear cmos.
After I flashed my nand an reinstalled, I checked my files. An I'll be damned. My recovery image was saved as of 1980.01.06
I remember, if your cmos battery gets low, this is the date it has or somewhere really close to it.
Did some looking around, only thing I could find relevant was when gates signed with IBM was in 1980. It would be interesting to know if he's linked to every computer in the world from his original programs he wrote.
@cbcuz24
Yo good looking out on that 15f version it worked just fine for me....
@thekraven
Great work on cai I hadn't installed cai since you took a break and I must what a great improvement since the 9a version...keep up the fantastic work as well as the work with tdm I'm waiting patiently for y'all to finish that ics kernel :D
GTR, AOKP, MiRaGe, CM9, BOBZ ICS, GODZILLA, Harmonia 2.08 killing the game!!!!!!!
Couldn't get the other latest versions to boot up, and flash 15f, as inceyet suggested and it worked perfectly. The rom is working great so far. Thank you for the ROM, looking forward to future updates! :)
@cbcuz24
@thekraven
No problem :thumbup:
I've flashed back to this last night. I did some of the build.prop tweaks they were talking about in quatt, then did the egl edit. Its never worked so completely good with great battery and data speeds.
Cai working great :D
Reactions: inceyet
I installed the original Alpha 16 build 16c?... well anyway the volume does not work for any media or system tones. Is there something I can flash to fix this?
I love the new build :) it just has a couple quirks.
EDIT: Weird... rebooted and it fixed it... really should start doing that BEFORE I make these posts :/
Why wont the newest version work for me? It keeps doing the blue matrix deal for hours on end
A handful of us have that, not sure why. I have to use 15f, nothing since then will get past the CM CID boot animation, if that is what you need by "matrix".
Tried it, works for a little bit, then it keeps force rebooting
All I gotta say is you da man The Kraven I was considering just sticking with ZVJ and Hydro Rom but after downgrading and Running this I am not gonna go back:)
Equatorial
