[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
Re: [WIP][ROM]COLD AS ICE-CM9 Sprint LS670 3/29 ZVD basesband Alp
Please respect the devs work and wishes... he has asked that you do not put up any mirrors. He nor anyone else should have to register at your site which in a way is also against forum rules... (Do not use the forums to promote external websites, blogs, promotions, contests, services, affiliate ID's, or other products, without prior authorization.)
The mirror link has been removed from this forum... if Kraven says you can post up a mirror.. then go ahead and do so.. but for now it has been removed.
Alright, Thanks. lol
On alpha 8 I've noticed the data still goes on and off repeatedly, causing my phone to heat up. I've tried all the various data toggles and rebooting
Also any time I touch the screen the physical buttons light up. I've noticed it with the last couple of builds.
Wifi still works like a champ.
to anyone who is intersted, Kraven added the magic smoke LWP to A8.
im having the same problems to . Also to lock texts I have to do it twice because it never locks the first time. Also hitting the settings button in the main text screen it does not always give the option to delete messages
I'm stoked. Does anyone know when 4.0.4 is going to be released.
Haha first rule of CyanogenMod: DON'T ASK FOR ETA'S!
If you didn't know before, now you do. But I'm as excited as everyone else here for 4.0.4 :D
I'm also getting intermittent data. I love the ROM, but the data issues are the only thing keeping me from making this my daily ROM. I tried the instructions given in the OP, but to no avail.
Any other tips and tricks?
Thanks for the great work on this ROM. :)
The toggle thing is the worst part of the new ROM for me. Some reboots, notification area toggles work. Some reboots, they don't. Sometimes a deeper look at "settings" shows airplane mode on, mobile data off, but the phone connects to wifi or 3G like nothing's up. It's super wonky.
Latest issue: Stopwatch & Timer app stops counting down if the screen goes off. I'm not certain if it's due to my CPU clock going down significantly when the screen is off, or if there's something bigger tied into the regular clock not really updating much when the screen is off. I'm guessing the latter - countdown starts up again when screen comes on, clock rights itself after a half-minute of screen being on. If they're tied together to some process not keeping time when the screen is off, . . . well.
I finally rooted and flashed my ZVC Optimus S. I was going to go to ZVH (HyrdoROM like I did for my daughter) but thought I'd stop by on ZVD for a test drive of Kraven's CM9. Wow! Just Wow! Just freaking Wow! I can't wait for this to work well enough to use full time.
My 3G data didn't work so I Nandroided it to play with later, but most other apps seemed to work. I moved on to Reborn ROM as a (hopefully temporary) daily driver.
Don't know if this has been reported, but I had a tough time shutting it down. Several times when I tried to shut it down, it just restarted. I seriously was beginning to think it couldn't be turned off and that I'd need to pull the battery. But for some reason, after about 3 tries, it finally shut down. The same thing happened to me again. Both times that I got it to shut down was by quicly powering it off before it completely booted up. Not sure if that helped or it was a coincidence.
Did I mention Wow? :)
Just for references sake, I used Kraven's CM9 A8 all day yesterday with no mobile data or WiFi issues after simply turning mobile data and WiFi off and on just once each.
I always find it a bit cleaner to flash the ROM, boot in, then reboot and flash Gapps. I probably got into this habit after having lockscreen issues with my Xoom when installing a Team EOS ROM while flashing ROM/Gapps at the same time.
Maybe it's a bit of paranoia taking over, but I just think it creates fewer issues. :cool:
What's magic smoke?
an alternative definition (besides the correct live wall paper answer)...
magic smoke is what is used in electronics to make them work. the magic smoke is added during the manufacturing of all chips... if you ever do something wrong and let the magic smoke come out, it won't ever work the same again. :D
haha !
THANKS :D
uhh snaps new radio :D
To do this what steps do I have to take exactly? Should I just data2ext --disable from adb, flash the new ROM and enable it? Or would I have to retake all the steps such as flashing the data2ext file and inputting all the commands into adb again? Thanks for the response.
EDIT: also what is the difference between mounts2SD and data2ext?
My apologies for taking so long to answer this question, You shouldn't have to disable data2ext, simply flash the new ROM and you should be good. if you aren't, as I said, try flashing the mod I released in the forums here, Although until I get around to updating the ZIP, please copy e2fsck from /sbin/ in recovery to /system/xbin and /system/bin and chmod it 777 before rebooting. You should be good. Mounts2SD has a couple features that (I'm not sure so don't quote me.) data2ext doesn't have, However Kraven's CM9 now supports sd-ext partition mounting by default since /etc/init.d scripts are executing perfectly now (Thanks btw Kraven :D)
EDIT: As least I think it does, I forgot to install my Apps2SD mods and it loaded my apps and data partition from the SD-EXT partition when I installed it..
aimalee
