rebel69ization
- Jan 23, 2012
- 501
- 106
- 0
Why min so high?
So how stable is this? I see that everyone is rocking this rom and Im still using an ICS the on theKarven cm7....
I didn't think it would do anything, but...wait a second...just sent and recieved MMS successfully as I was typing this.
In GoSMS, go to Settings > MMS settings, check Fill APN configuration manually, set MMSC to http://mmsc.vmobl.com:8088/mms? MMS PROXY = 205.239.233.136 and MMS PORT to 81
edit -- I'm sure there is some system file this can be changed in to make MMS work with the native messaging app, but I thought someone in this thread said there was a problem with the stock app. I don't know anything, clearly, but hopefully it helps for somebody.
Here's a testing kernel based on Gingerkernel ICS with a few patches from the p500 kernel. Vsync off makes the ui more smoother, qtaguid filter supposed to fix battery stats, Bluetooth tethering enabled (future use), Camera preview patches (future use).
Goo-inside.me Downloads - Downloading hk-ICS-test1-kernel-cam2-signed.zip
OV Owner, but i am running this as soon as i heard that this works on the OV, just a few bugs i didnt get to test mms, text works. the only problem i had was i open an app or go into settings and it would freeze and reboot on its own. i put the clock to 864 and the freeze/reboot ruduced. other is the battery, i had this charging all night, and it didnt charge, it kept saying to conect charger, i did but all it did was uncharge. i have some pics. another one is, well dont know how to explain but i press the power button to put it to sleep and it would freeze for like 5 secs-10secs. great port i like that 3g works here, i hope this helps you into making this rom more stablei have 2 pictures
v
Did you do a clean or dirty flash?
Sent from my VM670 using Taptalk 2
Clean install as usual
Running this with drew's new kernel, v2. When I try to open my emails in the stock email app, nothing will show. Like, a new window will pop up, but no text inside the email will be visible.
v
Umm, why is your status bar bright blue?
Everything is for testing, so some stuff might perform better or worse.Should we use this or hydrokernel?
Another test kernel.
Goo-inside.me Downloads - Downloading hk-ICS-test5-kernel-cam3-signed.zip
