[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
Re: [WIP][ROM]COLD AS ICE-CM9 Sprint LS670 4/5 ZVD basesband Alph
Testing the new kernal out and its a first my phone is running stable past 806! Sitting at 825 for a bit now and running buttery smooth! I love ics!!! Lol iPhone better watch out Android isis getting more stable and smooth by the update! And way to go thekraven, I have used your Roms a longtime , and will stick with them as long as I have this phone!
Edit: anybody having issues downloading apps off of the play market error 502
Is there a way to see what the exact battery level is in the notifications bar?
settings, system, status bar, battery status style, choose percent
Reactions: Lolanerd
Cool thanks, also does this rom come with a wifi tether? Because I tried using foxfi but it doesn't seem to work.
This has probably been asked before... but were you guys going to work on a ZVH/ZVJ compatible version of this rom? :D
I'm getting this weird thing where the body of all my emails is invisible. The links and all are there but I can't see the words. Also, is there a wifi tether? Or a recommended one? Because foxfi isn't working for me.
He may port to zvj. Who knows. Why do people care? If you want the rom downgrade to zvd. There is no benefit running zvd vs zvh vs zvj. Baseband is baseband.
a guy on the previous page the same question
Disappearing text is a known issue. Delete GMail updates or integrate them into the ROM with TiBu, answered a number of times already.
Seeing lots of reports from newbies to the thread about known issues. Maybe you should read the previous posts if you want to be alpha testers?????
Yes thekraven doesn't post all of the bugs in the OP just for the hell of it. Definitely worth reading before posting
Sent from my LS670 using Tapatalk 2
Don't have any problems with viewing emails, works perfectly on my osv. I installed the new test kernel and I can overclock to 864 Max which is great, and my mms is
receiving, downloading but I can't view. Does this have anything to do with the cam? It does take pics. Also what does error in SD card download status 7 mean?
sent from my icy cold OSV 4.0.4
Beanz2003
