ARCHIVED: [ROM][FASTEST iHO]ICSandwich2.3.7 [05|21|12]
Status
Not open for further replies.
Re: [ROM][AOSP]ICSandwich2.3.7 [04|20|12]
I've had the issue before, until I started using link2sd and a second sd card partition, never had the problem since! :)
I've never been able to not fix it by clearing the cache and force closing the app.
I've tried that at least 10 times if not more haha and it still does not work. XD we might have to wait and see if it gets fixed on the play stores next update. Oh and I went back to the old market and it isn't working anymore either Dx
This is my daily as of now. I was starting to get freezing more frequently on Jerryscripts usually stable builds. This is exactly what I want! Might not be 100% ICS but its stable!
CyanogenMod can't include GApps in their releases, and neither can anyone else. Please remove them ASAP and instead post a link to where folks can download GApps themselves.
Just watching your back. Don't let your ROM get taken down because of something stupid.
In other news, I like the design of your OP, looks great!
Definitely the best gb ROM ever. The smoothest!! Just do remove the gapps.. btw, can I get the link for that OP or whatever kernel? :)
Ok, starting to have my first problem. Seems when I move an app to SD it eventually disappears from any homescreens and the app drawer... only way to open is moving back + reboot or through G. Play.
If it helps, I did in fact flash tvalls kernel yesterday.
Where did u find it?
He has a thread just skim the recents for it. His kernel is Bobzhome modified
EDIT: http://forums.androidcentral.com/optimus-v-rooting-roms-hacks/162598-rom-tvalls-iho-roms-kernel-thread-hijacked-new-post.html :)
Reactions: KeviiinS
Installed and runs smooth. Will comment back if I have any bugs. Thanks
Is the BobZ kernel that comes as the default not up to date or something? Or is Mirage generally preferred? I've used so many ROMs at this point I can't keep track of kernels. o_0
I had the problem OppyV had as well. Took a couple of reboots to get things right.
Reactions: KeviiinS
So may have found a bug or something, when I install an app then move it to my sdcard and restart my phone the app disappears from the list and my home screen but is still installed.
Sent from the bottom of the ocean.
Status
CrazyParis
