ARCHIVED: [ROM][FASTEST iHO]ICSandwich2.3.7 [05|21|12]
Status
Not open for further replies.
Is this meant to look like ics?
Yes! Wow I got to say this is a super fast rom! Even on stock settings 600mhz. Found two bugs. But I can live with it if its this FAST ism really amazed!! Oh and nice come back (bootloop) haha you got me!!:)
1. Setting-volume fC
2.setting-language input-voice recognizer Fc
and the one posted above!
Thanks great rom
Re: [ROM][AOSP]ICSandwich [04|05|12]
Ian using vm670nh. Cwm 4.0.1.5
And this is a highly themed,with lots of speed, ultrcharged 2.3.7 based off Google gingerbread and iho! Correct me if Ian wrong ;)
Unknownartist, I think you might want to add something like this being gingerbread to the title of the thread... or not:p
I can't believe people can't tell the difference..... They go straight to comments rather than viewing screenshots and comments. :/
Reactions: thaunknownartist
People's reaction:
-Sees ICS- HOLY FUDGE, Is this working?
I mean, just look at how many views this thread has and it hasn't even been 24 hours yet. :P
nice rom but i cant seem to find the lockscreen you have on your screenshots! im desperately trying to get that set up on the phone. i tried all the CM lockscreens but no luck. any help please would be greatly appreciated. thank you
Can't seem to download, anyone else having this issue?
hes using widget locker :p
That's the build in Cyanogenmod Lockscreen.
-Ringlock
-Minimal Unlock
-Holo
-Center Widget
Go throught the settings and you'll find it. ;)
With the wife for the night, leave a list of errors, bugs, and force closes so that I can begin V3 tomorrow, time to enjoy before she leaves me for the week.
All of the bugs so far:
  • Swype is not working too well. If you try and use it in portrait mode, it does work. (version of Swype is not mentioned)
  • Setting-volume fC
  • setting-language input-voice recognizer Fc (and its setttings)
  • More>4G Settings FCs
  • Doesn't vibrate while using GoSMS regardless of settings (triple checked all settings.) Haven't tested with messaging.
  • Display>Brightness FC
  • (Might just be phones unique setup) Play Store constantly FCs after restoring some apps from Titanium Backup or using Link2SD.
Everyone else should just c/p this list and add to it.
  • Setting-volume fC
I am using stock messaging and I have vibrate, will check with go SMS.
The settings all need to be reworked and scripted as I brought them over from my EVO 3D so I could fix all those in the morning.
I will decompile and read into the swype problem, not really a swype user so I need to give that a try.
Market only fc when making vendor updates, mine did 2 loops and is fine now.
Continue the good work and we will get this complete soon
FYI: There's regular Swype and then there's the beta. The regular Swype is crap so I'm not sure why anyone would use it but I'm sure people do. That's why I added a note about the version not being clarified.
Also another:
  • App disappears when clicking into a text field. The keyboard pops up and shows the desktop background. App reappears after typing a few letters. Tested with stock KB and SwiftKey 3 beta.
Also another:
I have noticed that too, when I press search or market the keyboard disappears until I text.
Now that you have mentioned that there are multiple Swype apps this is something that needs to be verified.
Status
mrrice360274
