[ROM]GB 2.3.4 gingerbread-evo-deck [1.0][2.3.3 Stable][1.2c][2.3.4 Beta]
Not that I have noticed this but I have wondered why sometime I go to click on thee notification it goes away instead of going to my message or what not.
Sent from my PC36100 using Tapatalk
I'm experiencing the same issue. It likes to cut out whenever it feels like, now it is decently fast when it does stay connected. Can be very flakey though. I would flash 1.2zPS to see if has been fixed, but I don't have enough battery power. I'll report back once I've done it. Oh...one thing I do sometimes to get the data rolling again....turn on auto syncing. That usually gets my data going, just turn it off when your done because you don't want to drain that battery dry. :-)
Sent from my evil hideout. MUWHAHAHAHA!!!!!!
Ok...i have reinstalled z. Wiped everything and started fresh 3g connects very slowly for me or not at all. I am going to try this for a day and see if it works out. This is my only problem with this rom.
Simple my friend. The voicemail.apk is Sprint's visual voicemail application. It was bundled with the Google apps so when you flash the gapps, you'll also have VV. It works beautifully I must say, just as you would expect it to. :-) The other one is just the regular Google apps package.
gotcha. I appreciate it.
My only problem with this rom is the garbage camera app. I juat dont like the ASOP camera. Is there a way to strip out a sense camera and use it with this rom? Also i googled it and somw people spoke of a miui camera apk... But I don't know what that is
If I'm not mistaken the HTC camera is just a stretched version of the AOSP one. The MIUI camera is the one that comes pre-installed with the MIUI ROM. I'll see if I can find a link for it, as it would be cool to have a full screen camera again.
One other? My gps indicator never shows up. I have a check to see if it's on. This normal. It does show in the dropdown status bar though
I believe that is just a function of GB. My CM7 ROM only shows the GPS icon in the status bar when it is active.
So that flashable zip..will it override the current camera or install alongside it
I'm not entirely sure, about to flash it and find out. Will report back with results. All I can say is thank goodness for nandroids...lol.
I don't have any indicator (even when using maps or foursquare or something that needs it) no indication at all that it's on or off
So what was the result? Do you get 2 cameras or it replaces the stock?
Sorry for the delay...just got done flashing. I can happily report that I now have a full screen camera!!!! It does not replace the stock camera app either, so just in case you like it better you still have it. It does install it to the system so it doesn't have an uninstall feature after flashing. Just wanted to point that out in case someone is wondering. Everything works just as you would expect it to as well. Joins up perfect with the stock gallery. One thing though, I haven't found a way to switch to the front camera inside the MIUI camera...but I digress. Go ahead and flash away peeps and enjoy. :-D
P.S. Make sure to grab the third zip in the list. It's marked as the one that works and let me tell you...it sure does. Oh, yeah...you don't need to wipe anything before flashing this...at least I didn't have to. :-P
So I absolutely LOVE this rom. My evo flies...but I just can't get the GPS to fix. So I'm gonna try another one. Kinda sad. I'll keep checking back though for when it works out of the box. After going ASOP I think I prefer it over Sense..except camera :).
Forgive me, for I have sinned. I wanted to try out a Sense 3.0 Hybrid ROM and liked it except for the fact that the battery life wasn't anywhere as near as good as this ROM. I'm currently flashing 1.2z now :)
Is the GPS not locking on for you?
Dubs...for shame. :-P For real though, what your favorite feature of 3.0?
WesBadamio
