jruizisenberg
- Mar 20, 2011
- 6
- 0
- 0
Just in case you haven't seen it, please read this:
[NOTICE] Gingerbread Related Bricking - xda-developers
Recent apps aren't there unless you install the patch for it. The toggles aren't the same either since it's uses the newer since version which has them under another tab in the pull-down.
Hey guys, I have the 2.0 remix, and want to go back to 1.6 with the issue popping up. Problem is when I connect my phone and choose disc drive it enables but won't show up on my computer. Any ideas?
I am reading through the XDA thread right now, Not a chance I will be trying this ROM out... I don't want to risk it bricking on its own...Went through the thread at xda which is now 28 pages long. Based on what I read, there appears to be a real chance that the leaked Gingerbread radio can brick your phone permanently. While das BAMF 2.0 has been running fine on my phone, I have decided to return to DB 1.6.3.
Does simply flashing 1.6.3 stop any possible bricking from GB? If not, do I have to flash a different radio?
So what did I do? I went here to see if installing back my stock radio (that corresponds to 1.13.605.7) will work back again. And glad I did or else it could've been worst.
I had (downgrading from 2.0 GB to 1.6.3 Froyo)![]()
1.13.605.7 is actually the radio associated with the OTA update, so if you have problems with it, you could even flash the 1.12.605.6 version (pre-OTA radio). Either way, it's the radio, not the roms, causing the bricks; so, you definitely want to flash back to a non-gb radio.
Actually those are not the radios, it's the base software which the radios run off of.
Stock radio: 1.16.00.0223r
New radio: 1.16.00.0402w_1
Don't want to come off as a know it all or anything, because I'm definitely not
And thats what I did, except that I matched with whatever I had (which was 1.13.605.7)![]()
