[ROM][GB][5.23.11]Das BAMF 2.0-5
And Btw, this rom has awful battery life :(
My phone went from %96 to %37 after a three hour drive in a 3G area. It's 4G radio is definitely alpha phase, I was getting average of 5Mbs down and 2Mbs up. Still has worked to be done
Sent from my ThunderBolt using Tapatalk
What kernel and version are you running?
Anyone having problems connecting to wifi networks? I haven't tried from home, but got to work and it won't finish obtaining ip from any of them... :confused:
Did you install using Rom Manager? There have been reports of WiFi problems when installing using RM. Better to install using clockworkmod. May want to reflash using CWM. Good luck.
Reactions: nate44
Sounds like it doesn't get along with your phone. Battery life has been excellent on my Thunderbolt. 14 hours and my extended battery is at 55%
I actually used CWM the whole way through except the radio install with hboot first thing... Hmm, I don't wanna have to wipe and reinstall all over again... :( I never use wifi anyway, maybe I'll just wait for the next update...
Make sure you're wiping more than once in recovery. I wipe 2-3 times all three (data, cache, dalvik) and haven't run into any problems that haven't been reported. Also make sure you're not restoring any kind of system data to the new ROM.
Flashing now, new boot screen took forever, but eventually loaded up. Looks very nice so far and the new boot image is pretty sweet.
Was on the liquid gingersense rom for a little bit but way too buggy for me. Just flashed this and its much better IMO
do i have to rename it once moved to to sd card??
If its the rom zip file then no, just clear data cache and dalvik and flash with cwr.
If its a radio it needs to be named pg05img.zip and placed on root of sd card, and flashed in hboot
ok thx....how about the patches do i just place on sdcard along with the rom n it automatcally takes care of itself?
does this release have the notification bar like in 1.6.3. If not is there a way to get that in this release. I like having the power bar and the removed recent apps.
Recent apps aren't there unless you install the patch for it. The toggles aren't the same either since it's uses the newer since version which has them under another tab in the pull-down.
