[ROM][GINGERBREAD] CyanogenMOD 7 Nightly Builds.
Thats what i use to (Vignette) , its much better then the stock camera on CM7 :cool:
so i accidentaly deleted the little phone icon in the bottom corner of the home screen launcher... i tried to add it back but i cant find which one it is, none of the ones from custom launcher>activities>dialer is working the same...
any help?
any help?
What you do is find a blank space on your homescreen, long press and choose to add a shortcut and choose "applications". Srcroll down until you find "phone" (that's your dialer) and add it to your homescreen. Now just drag that shortcut onto ADW and your all set.
I have a .apk file for MIUI camera #17. I posted it in this thread not long ago, but if you can't find it I'll post it again.
Well I've tried several and they don't work. HTC camera better than miui, vignette, and stock cm7. Waiting for camera upgrade before I go back to CM7, but I freakin miss it!!!! Need reliable high quality camera. They will have something special for CM7 I'm sure
They modify the camera in CM7 as best as possible, but the mediocre interface comes from AOSP. So the only way it will change drastically is if they were to write up their own camera app. i.e MIUI or HTC.
I don't expect my phone to be a digital SLR, so quick and dirty is good for me. The vast majority of the pic's I take are of customer sites, to document what a mess I walked into. The rest are blurry kids in action shots, but I'm not sure that the problem there does not lie on the other side of the lense.
Just make sure I am doing things correctly: to flash a new nightly, I only need to wipe cache and dalvik cache, right? Nothing else like a factory wipe? Do I need to reflash gapps and incredikernel?
Right. No need fore a full wipe, cache and dalvic are enough. You won't have to reflash gapps, but you will need to reflash Incredikernel.
I just like the widescreen photos and option for 720p.. I bet the cm7 camera will be better than anything else soon. I have read on these forums that there have been several improvements in the past few weeks. 720p isn't a big deal since the phone itself is only 480x800!! I guess its just the theory of the thing, but when showing people pictures on my phone I like them to be resolution of phone..ie widescreen
StevieD49
