[ROM][GINGERBREAD] CyanogenMOD 7 Nightly Builds.
couple issues i had with #8:
everything was great for like 10 hours, running the slayher .37 kernel, until i rebooted. then my texts were erased, digital clock widget went a little crazy, and could no longer long-hold the homescreen for a new folder or app (not sure if this is an option i mistakenly turned off in adw, bc i dont usually use adw, but i looked around and didnt find anything).
after the reboot the launcher also began to lag a bit.
but everything was swell before that.
might try a different kernel combo or flash 9 or both.
edit
also errors sending files from my cpu via bluetooth
I had some crazy issues to with number 8... i went back to number 7. works fine :)
I havent had any issues with #8,using the new kernel my phones been on and used alot today.15 hrs and 40% battery ,70 sms,50emails,websurfing,gps use with trapster,phone hasnt been sleeping hardly any . Stock battery in phone today.Checking weatherbug alot because of severe weather.I was getting good battery life with chads other kernel too.
Im thinking #10 will be be next nightly if it doesnt fail .
sent using TaPaTaLk
The facebook apps should still work from what I understand, or have I misinterpreted something.
<<Sigh>> No build last night again...
I'm thinking the build bot has run off with Bender and Charlie Sheen
I think you can get a glimse of the build bot back by the bar!
Pville.... Completely off topic to this thread but I cant find my answer anywhere and I know it is prolly really obvious, How do you get a picture of that size or any size in your post??? in other threads I have only been able to use the attach option and the pic or whatever is small. you can send me a PM if you want so we don't clutter up this thread with nonsense, but i have to know :)
Use the Insert Image button in the Reply Box toolbar (looks like a square with mountains in it) and insert the URL of the pic you want to display.
I know that but here is my example... I was on another thread and wanted to post a screen shot of my phone, how would I turn that into a URL... I really do hate to talk about this in this forum since it has nothing to do with CM but know one else would help me.
No problem. Set up a flickr or picassa account. Then you can use the "Share This" option and grab the url for the pic. If you use Flickr you will need to download an app from the market to upload from your phone.
Reactions: md17 and ssethv
You are the STIG, my friend.... thanks :)
SAVVYSCLUTTER
