wkupike2000
- May 14, 2010
- 59
- 1
- 0
Here you go - Everything you need to wipe and load.
http://forum.androidcentral.com/htc...oot-rom-your-droid-incredible.html#post628102
Just make sure you use a file manager to move all your pictures, and files that are stored on the phone partition to the SD Card. When you wipe data, you will delete the contents of the data partition on the phone. The SD Card will be ok, so just make sure you back up any files you want first.
Titanium Backup is also a good way to do this.
Hope this helps.
So i fully wiped per instructions, flashed the Night full #6 and then from same recovery I flashed Gapps, then let it reboot. I then went back to recovery, cleared cache and Davlik then flashed incredikernel. Rebooted and then ran TiBackup to restore apps and system data. For some reason I started getting "android.media process" FC's over and over and could no longer download from Market at all.
I then restarted the phone and each time it stays in the blue android guy boot screen for Cyanogen Mod 7 endlessly no matter what I try. I repeated the full wipe process again and the other steps and just had the exact same problem and now am stuck with hanging boot screen no matter how long I wait or do battery pulls it still hangs at boot screen. Please help as I basically can't use my phone.
