[ROM][GINGERBREAD] CyanogenMOD 7 Nightly Builds.
I've seen the best method is to download the ROM from ROM Manager but then cancel out and install from SD card. Well where does the ROM you just downloaded, in my case nightly #13, get downloaded to? I've searched all over my phone & SD card but can't find it. Thanks.
It's in /clockworkmod/download/mirror.teamdouche.net/get/inc/cm_inc_full-XX.zip
Reactions: wkupike2000
The newest Incredikernel does, although it doesn't seem like the simplest thing to do.
Chad posted the instructions for it here.
Perfect, thank you :) when I had the PrePlus, you could really tweak the voltage through a nice UI, hopefully someday, someone can put this into a UI for android too.
but this works to... just a little more work I have to do :)
Has anyone else had issues with the market? I get force closes for android.process.media upon opening it, and once the download starts, it moves incredibly slowly.
can you be more specific.... what were you doing before this started happening? did you flash anything new at all?
I attempted to update maps with the newest version (opened the market>My Apps and updated all, which was Maps and Gem Miner) I got a force close on the process mentioned, though the download started. It got <1% complete (97kB downloaded) and stalled out, staying there for 15 min. Internet worked fine, both checking email and browsing.
I stopped the download, rebooted, and tried again with the same results. I also attempted to download gapps from this posts front page, but it also wouldn't move beyond the initial download state.
I was running CM13 with incredikernel 2.6.37.2, both flashed this morning.
I did a full restore back to 11 and life's good again. Depending on how everyone else is doing with this, I may try a full wipe and go back to 13 or I may just wait for 14 without wiping data, though I really like the camera improvements and the profiles...
Updating google maps after updating to #13 I got a failed update on maps, but I tried again and it worked.Other app updated with no issue.
These new profiles settings remind me of the profiles settings on my old berry .
in other un related news : Charlie Sheen got fired from "Two and a Half Men"
Reactions: rpz3.14
I was able to update Google Maps and Root Explorer just now Running CM13 with stock kernel. I'd try 13 again with the stock kernel and see how it works.
Reactions: rpz3.14
Another reason to love nightlies and CM.... FREE HOTSPOT :) coming in very handy right now!!!
For those waiting with Baited Breath........
RC2 is available in ROM Manager!
It's #13 with more transaltion corrections.
EDIT: Opps - spoke too soon. It's a placeholder for tonight's build.
So.... Is RC2 just #13 with more corrections and its official... I really don't understand.. why cant they just call it nightly 14? or is it the end of the nightly's? can you please explain what implications this will have :) and also what does RC stand for?
First - ROM Manager RC2 now works!
Second - There will still be nightlies. An RC (Release Candidate) is a stake in the ground when the CM team feels that they have made good progress and declare a waypoint.
The official Bug tracker does not take reports on nightlies, but they do on RC's. Development will continue until such time as the CM team decides that they have a "Stable Release." Then work will stop on CM7 and start on CM7.1. The cycle continues until they decide CM7 is done and they move on to CM8 (which I will take a SWAG at and state could be Ice Cream based).
So don't worry about RC2, it's a milestone more than anything else and #14 will be out shortly! ;)
So basicly tomorrow I should flash the rc 2... Not that it will make a difference on my incredible but for the simple fact that I can help the cm team, With sending reported bugs? Am I close to getting it or understanding it?
Also since it's not a nightly, do I need to do a full wipe before I flash rc 2?
-Sent from my HTC incredible via Tapatalk
If you want to submit bugs to the CM Team on their bug tracker, you will have to stick to RC2 until RC3 comes out. As soon as you flash anything past 13 on the nightlies you are post RC2 and out of the running. I know that the devs for the DInc read the XDA threads. I’m not sure if they read these threads or not.
Regardless, posting "bugs" in a thread like this is a good way to document/report bugs. Sometimes it's not a bug but a brain fart forgetting to wipe Dalvik! ;) (been there...done that)
You should not have to do anything different to flash RC2 over 13. Some people use RC's as a milestone to do full wipes if they have been a long time between full wipes, but it's not necessary.
Since the only changes in RC2, other than translation updates, from 13 are:
Added notification profile support.
This adds finer-grained support for notification tones, and groups settings into profiles,which can be easily switched. API support is also added, allowing configuration, and profileswitching from another program (e.g. Tasker, Locale).
A profile represents a particular set of settings, and could be for example "Silent","Office", or "Night". Each profile contains the settings for a definable set of applicationgroups.
An application group represents a group of applications to which the settings should apply.For example "SMS" might contain "Messaging" and "Handcent".
The applications in an application group are globally defined. The notification settings foran application group are per-profile.
For each profile/application group you can define behaviour for lights/vibrate and sound. Either you can suppress, override, or leave unchanged (ie system, or app default).
Example: Work : SMS vibrate. Ringer vibrate. Email no alert. Gmail vibrate.
Night: SMS silent. Ringer on. Email silent. Gmail silent.
Some sd-ext changes for other devices and the RC2 Mod Version. I'm going to wait for the next Nightly to pick up the Profile Change.
Whew... Long winded... ;)
What is SD ext. I always get an error when trying to back those up...is this bad
No, it's a pratition that you can make on your SD Card we don't normally use. If you have not set it up it's empty when you do the backup so it errors when it tries to restore it. There is no need to set it up so don't worry about it.
FYI - the Hebrew translation for notifications submission that was part of RC2 has aparently run amuck and is showing the Update Notification Registration screen in Hebrew. So you may want to hold off on RC2 unless you need to brush up on your Hebrew and can read from Right to Left! ;)
Hopefully another RC will bring even more users to the nightlies! I know this thread blew up when RC1 dropped, so RC2 should in theory do the same thing:) We now have over 10,000 views on this thread, and still going strong! I've been working alot lately so unfortunately I have been away from my computer, but don't worry guys I've been keeping a close eye on the thread and of course flashing away! Let's keep this awesome thread up guys! CM7 nightlies for life! :D
I had to do a full wipe to 13 cause I was getting FC's out the arse. But I'm gonna skip RC2 and just wait for the next nightly
Sent from my INCredible phone
I went straight from #13 to #14 ,,,,,,cuz #14 is up :D
If I am running RC1 and want to upgrade to RC2, do I need to do a full wipe or can I just upgrade?
sukarisw02
