[ROM][GINGERBREAD] CyanogenMOD 7 Nightly Builds.
i went from the 12 nightly to the 13th one. the 12 the click optical button to wake the phone worked without a hitch every time. but now on the 13th its hit and miss and sometimes i have to really hold it down. is that a dalvik setting or something? when i went from the 12 to the 13 i didn't wipe any settings.
I cant DL the new nightly from my ROM manager... it says that there is "no ROM update currently avail" was working fine yesterday! why?
Just flashed #14.... Looks like I had to do it the old fashioned way, ROMmanager said there was no update avail, YET there was... If any one know why this would happen, please post and let us (me) know. If i have to keep doing it the hard way (im whining), then why did I pay for ROM premium?
ALSO, post any goods and bads of 14 or RC2 :)
I am definitely not happy with rom manager. It has made big mistakes for me and I paid for it wtf mate
Me neither, i used it once the first (only so far) time i loaded CM7 RC1 and it gave me trouble. Did it the manual way and things were fine. Luckily i didn't pay for the full RM version.
Does the cyanogen 7.0.0 rc2 support the wiimote? I read somewhere that cyanogen will support the wiimote but i am unable to do so on the 2 that i tried to use. Thanks for any help
ok i just installed the rc2 and the trackball still isnt working like it did in 12, i have it turned on but it wont wake up like build 12 was =(. i was really liking that feature
edit: im stupid. i was in the wrong area, i was in lock screen instead of just general settings for wake this device. doh.
I've never had any issues connecting to a Wiimote, I do it every once in a while to play some Gameboid. What app are you using to connect to the Wiimote?
I was running CM7 RC 1 and I followed the instructions and did a nandroid backup before installing RC2. I did not wipe anything, but just installed RC2 (as described in the cyanogenmod forums) via ROM Manager. Now all of my apps force close when I try and run them. I went in to ROM Manager and ran the fix permissions option and rebooted and that did not fix the problem. I have read where some people installed by booting in to Recovery and wiped the delvik cache and the cache partition and then installed manually, is that what I need to do? Or must I do a full wipe and start over?
Thanks for the help.
what I do is DL the ROM to my phone via ROM manager. shut phone off. boot into recovery, wipe cache (not data), wipe dalvik, then flash zip (rom), then flash the kernel you use (if you use any at all). then reboot... thats what works for me and everything is fine.....
question for you: are all of your apps for closing or just some of them?
Please read the OP. Or read the thread, it has been mentioned a few times that ROM Manager tends to bork things. Boot into recovery, wipe cache and dalvik, flash.
Also, can we please keep this thread focused on the nightlies, I understand RC2 is also CM7, but this thread is for the nightlies, let's try to keep it focused. If people would like to discuss RC1 or RC2, please create a seperate thread.
Reactions: ssethv
I agree. You started this thread and have everyright to make a comment like that. I do not feel as though it is my place to do it... again thanks for this thread Crondable... best thread by far
Reactions: crondable
Anthony Ads
