I miss nightlies.![]()
How do you like your new phone
-Tapatalk via cm7tized Dinc
okay my heart is racing, i just reloaded CM7 back onto my phone and booted just fine but i went and changed the prcessor to 1113 and i worked for like 15 sec phone then rebooted and now it wont stop rebooting what do I DO?!?! i didnt just brick this thing did i?
ive never messed with overclking it and damn now i wish i wouldnt have. F!
As you can tell I have removed (on purpose) the ADW settings, because I now only use ADW EX... Does anyone know how I could put my ADW EX setting in the spot where ADW used to be (which was right below CyanogenMod settings)???
much easier than that I have my ADW EX app icon on one of my homescreens. all i have to do is click on the icon and it takes me right to the settings. and since I completely removed ADW, i only have the option for ADW EX anyways.I don't know how you can add it, but I bet you can access the EX menu by pressing menu when you are on the main screen, going to more, and finding ADW settings there.
This was where settings where when I had ADW installed over other default launchers.
I am sure it can be done, I have been going through every file and folder imaginable in rootexplorer. i am just trying to figure out where I need to copy and place it.
Video recording is busted for me. I think this was working before, but I don't remember the last time I tried it. I reset it to the defaults and it freezes after 2 seconds of recording.
Not sure if this is the right place for this but I want to know how to install a custom boot animation using CM7 Nightlies and of it is even possible(currently running 28).
I read directions on how to do it but i am unable to delete or modify the system boot animation file.
I've tried root explorer, astro, and es file manager and none of them will let me get rid of the stock CM7 boot animation or put the custom animation in its place.
Any help would be greatly appreciated.
Thanks!!!
Im sure your right, but couldn't I in theory just copy and Place the adw ex xml or apk (whatever the format it is) in the same place that I removed the original adw from settings in root explorer?Unfortunately you cannot do this. The CM devs baked ADW Settings into the settings menu, so anytime you change launchers you lose that functionality.
I do this all the time using SuperManager app (like root explorer, but FREE)...Not sure if this is the right place for this but I want to know how to install a custom boot animation using CM7 Nightlies and of it is even possible(currently running 28).
Thanks!!!
