[ROM][GINGERBREAD] CyanogenMOD 7 Nightly Builds.
I think I am going to flash back to 26 or 27, I am having a lot of issues with 30... Random force closes and weirdness with my screen
-Tapatalk via cm7tized Dinc
NOT TO SHABBY.... conidering I don't have a TB:)
Tis been oddly quiet in here tonight... anyway... I flashed back to 28, and everything is perfect again.
Did you update Tapatalk today? That might be the culprit.
yeah, and nothing really changed, just stayed kinda wierd all day after i flashed 30... before and after the update.... also, I bought tapatalk for the freakin widget and also cuz its awesome, why then did they take away the widget... I mean it NOT that big of a deal, but you know what I mean...
good speed man, what did you use to take a pic like that
It is an app called " ShootMe" by johan Cloetens... It is by far the best screen shot app out there... and obviously you have to be rooted, which you are so no worries. also I use picasa app to upload my screen shots to my photos tab in my GMAIL acct. then I can access them and put them on the screen like you see there :)
and... all you have to do to take a pic is litteraly shake your phone in your hand and it takes a screen shot :) pretty sweet
Reactions: kaefbaml
Saw some posts where #30 with the latest Tapatalk was causing a lot of FC and other issues. Might want to uninstall Tapatalk and see if the problems presist, but I see you already rolled back so no biggie.
yep, im sittin pretty on 28 right now. and at least my camcorder works to. no noticeable changes other than my phone is working like it should now :) also, I stated a thread on the main page and was wondering if you saw it.... I didn't want to clutter up this one, so i posted out there... if you get a chance see if you can help. its about my notification bar :)
SWEEt man thanks, this is a w e s o m e
Don't forget to open the app back up after you take your screen shots and select quit... when i first started using it, i forgot and every time my phone shook in my pocket or anything like that it would take a pic, lol. i had a crap load of pics before I realized it... :)
You now what I just noticed, that actually really pisses me off... ALL of the ringtones that came standard with android are pretty much GONE. i tried to change my ringtone/notification for my alarm clock and my android system tones are like almost nothing, before there was a bunch. they havent change in contacts only alarms settings... dang man.
FIXED: I had to actually go to the market and DL another alarm app just to access all of my android system ringtones and notifications... man, what in the heck is CM doing lately, i mean, these little things (bugs) are starting to jump out every so often. and so is the joy of Rooting, ROMing, and Nightlies :)
just looked at the gerrits, so far looks like not alot for us again, but a whole bunch for the liberty/aria... anywhoo.. im hittin the sack. see yall tomorrow, or later tonight in bed on tapatalk (if i cant sleep)... :)
PVILLE... Completely off topic (and not thread worthy)... how do I know if I have a Amoled or SLCD screen... I have obviously researched it but I cant tell what kind of hardware (002 or 003) im using... i can find that info on my phone anywhere. I remember when I rooted my phone, but that was soooo long ago. im just curious.
If you have a pair of polarized sunglasses, put them on and tilt the device from portrait to landscape. If you can see the screen for the entire rotation, it's an AMOLED, if it dims and then blacks out, it's an SLCD. That's how I finally figured it out.
uhhh. never heard that. But ill try it :) thanks
You know I don't remember off the top of my head. When did you get it? If it was at the end of '10 or later, then it's probably SLED.
also without sunglasses needed you can :
go into a dark room and load up an image with a lot of black in it. If it's completely pitch black in the black areas of the image, you've got AMOLED. If you can see some light bleeding through in those areas, it's SLCD
Abidalyy739
