[ROM][GINGERBREAD] CyanogenMOD 7 Nightly Builds.
im going to flash #31 right now and im going to change kernels and see if i can get a difference out of battery. i just went 2 hours+ with out losing 1% so thats GOOD.
going to try incredikernel 2.6.37.4
found it man super simple app load it on your phone and then add what u want to add. read this for more info and d/l link
Change Carrier Name(app)V1.2 - xda-developers
This is awesome. I updated it to " " and am loving the nice clean (Verizonless) look.
I think you will be happy with that new kernel.... I didn't seem to have success with it until build 28 and this build. Let me know how it works for you
-Via Tapatalk on my hINCm7
Just now had time to remove vzw from notification bar with that app, better now ha ;)
What's the difference between RC3 and Build 32? I'm running 31 right now and wondering which, if either I should flash. Everything seems to be ok right now with 31.
Hey how did u change the toggles in the notification bar. Wifi GPS bt etc...
Android, the best community. Sent using tapatalk!
menu button>settings>cyanogenMod settings>interface>notification power widget>widget button, then tick or untick the ones you want in the notification bar.
just below the page the "widget button" is on you will see another button "widget button order" so you can re-arrange then as you like :)
#32/33 will be the build after RC3 and will incorporate more fixes. You can view the RC as another Nightly and flash like always.
Reactions: MHBlink8
So, I found a nifty link for a CM7 changelog in the front page comments for RC3. I have only looked at it briefly, but it seems quite complete.
Link
PVILLE... what are the main differences in incredibly re-engineered and CM ? jw. I think that Is the only rom i havene't flashed. what do you think of it ?
I ran the non Z ROM for a few days without any issues at all. I liked it. It was stable and quick. It's Foryo instead of GB so it does not have the GB backend enhancements. It does have the GB keyboard and a lot of GB feel to the UI. Looks like AOSP but it's based on sense so it has all the HTC apps in it. It's a nice bridge between Sense and AOSP.
Reactions: ssethv
I was on incredible re-enginerred before CM7.That was before the last incredible re-enginered update tho.
It was flawless ,but I like CM7 better :). CM7 seems to have more built in customizing to me within the cyanogen settings alone.
sent using TaPaTaLk
Plus, CM7 doesn't default back to a highly objectionable wallpaper after metamorphs (my wife was very confused after one update when she looked over on the reboot).
sent using TaPaTaLk
Yeah I agree. Since it's Sense, it's limited in terms of what can be changed/modified within the ROM, but what you can change works well.
asnes
