[ROM][GINGERBREAD] CyanogenMOD 7 Nightly Builds.
Finally had a minute this week and flashed 58. Looks good and operation is smooth. I was almost tempted to try skyraider but i'll have to save that for when i get a few days off work or something.
Hhhaaaaa!!! We'll see you in the SR4.0 when you get here!!
OK - So I was in West Virginia today and I was roaming on Extended Network (it's a Sprint area). I could recieve calls, text's and 1x data, but I could not make calls. I have System Select set to Automatic and roaming enabled in Mobile Network Settings, and I did a *228 Roaming table update just a few days ago. Has anyone else been on an Extended Network and not be able to make calls?
That's a strange one.... I live in an area that gets great 3g and 4g coverage, but sometimes I drive through the boondocks (not very often, I live in a metro area) but when I have I noticed that I was roaming or extended and had no issues making calls or recieving calls...
Keep me posted if you figure out the fix to the issue or a reason why...
Think I figured it out, with some help from XDA. I had switched from EVRC to EVRC-B many moon ago when I was on Sense. So I quick flashed Virtuous, did the ##778 routine and switched Roaming back to EVRC. I have to drive out there to test it but I'm pretty sure that's it.
<< Snoopy Happy Dance>>
WOW... you must have dug deep for that... So you drivin out there today just to test ;)
Later today or tomorrow. I'll post if it worked or not. I have a client out that way I can drop in on on Sunday, so I may kill two birds with one stone.
ive been reading up it sounds cool. until i get done with work next week i just wont have time to mess around with "new" roms...
@seth - 56 dollars for a tank of gas in ny!! wtf!!!!!!! want to sell my car now
@everyone - cm7 is so convenient. not having gingerbread sucks (on my thunderbolt)
That is crazy... 3.85 gallon in jax, FL... cost me bout 30 to fill up!! I bet it costs you more in NY
4.09 at one station in town here Jeesh - Explorer is now $70+ to fill. Can we get an ad based gas app that fill's us up if we click on the ad's? ;)
Lots of new changes in the next build - new kernel, 2.3.4, the changelog is down at the moment but whenever the next build happens there should be lots to play with. ;)
Reactions: zero neck
For those interested - switching the roaming from EVRC-B to EVRC worked. I was able to make calls in the extended network today! Yeaa!
Reactions: ssethv
you need to post that splash pic and zip that you made for CM...
A wolverine splash screen in cyan colors that i photoshopped.
(thanks to ssethv for zipping it up)
(rename file PB31IMG.zip, place on root of sd card, and flash in hboot, then remove file from sd card)
Reactions: Wanda
AjdinFaz
