We lost seth again - He's off on another ROMance!![]()
<<we kid because we love>>
Just a matter of time till I come backI love CM7 but the battery life isn't quite as good as another ROM at the moment... any suggestions as to why? I am actually contemplating doing a full wipe and starting from scratch with CM7, maybe that would make a difference.?..
I assume you're using incredikernel w/ smartass enabled. You might want to toggle radios as you need them. I only run radios I need when I need them. Saves them from draining the battery searching for signal or pinging for a connection. My wife calls me a radio fascist!
You assumed correctly, my settings are 128 - 883. I tend to underclock... I am not very familiar with toggling radios it is something I have never get my hands into. Of course you know have peaked my curiosity, and I would like to learn more where can I find information so I can read, Read, read, and read some more...
Sent from my ADR6300 using Tapatalk
I hope that the 2.3.4 release gets some more lively nightly builds going.
Noobish question, I'm running CM7 0.2.1 but I want to switch to nightly 58 since it seems to fix the "display" issue that myself and some other Dink users have been having. Do I have to do a full wipe or can I just go ahead and flash nightly 58 over 0.2.1? And di I also need to reflash Incredikernel and gapps again?
I just flashed the new nightly right over the stable rom, I had no issues... But as always, make a nandroid first![]()
Thanks, ssethv. I'm off th flash a ROM then.![]()
I'm assuming you already know this, but just in case you forgot.... Don't forget to wipe regular cache and dalvik cashe between flashing any new nightly... A full wipe is not necessary
Some say? Yoda seeks his advice on which ROM to flash*? Others say that his heartbeat is measured in Tweets per minute? All we know is? He?s called The Stig!
That's a strange one.... I live in an area that gets great 3g and 4g coverage, but sometimes I drive through the boondocks (not very often, I live in a metro area) but when I have I noticed that I was roaming or extended and had no issues making calls or recieving calls...OK - So I was in West Virginia today - don't ask - and I was roaming on Extended Network (it's a Sprint area). I could recieve calls, text's and 1x data, but I could not make calls. I have System Select set to Automatic and roaming enabled in Mobile Network Settings, and I did a *228 Roaming table update just a few days ago. Has anyone else been on an Extended Network and not be able to make calls?
