Only problem I'm seeing is twice now I've dropped to 3G and had to reboot to get 4G back. This is probably due to the new radio though.
Sent from my ADR6400L using Tapatalk
Lots of new radios... did you load the 2.10, or 2.11 or something else???
using the 2.11 radio.
I'm running the same radio and have not had that issue.
Does anybody know how to change the green into blue I saw it before
I saw it before that they PhotoShop the green sheet into a blue one and I don't know how to do it
You can google "How to change shirt color in Photoshop ( type your version of photoshop here), and you will find step by step vids on how to do it.
thanks I'll check it out later appreciate the advice sorry if I confused anyone
i got the "End Call" bug today -___-... this is gonna be a deal breaker for me, same issue i had with the VII and VI
Anyone else have a problem with swiftkey not working? I checked in the keyboard setting and it still shows swiftkey as the active keyboard, I tried a reset but no luck.
