[ROM] Gingeritis 3D v1.0 Beta VIII [8-24-11]
I was running Bamf 2.1 NTE and switched back to gingeritis 3d VI and then to VIII and in both my Gtalk and my camera keep force closing. Can anyone tell me what I am doing wrong?
Seems like the camera and force close talk are affecting alot of people. I think it has do do with the new Google voice update.
Unless that is installed without my knowledge I never installed that.
I went back to Bamf 3.0 rc 4.9 and everything is working. I only hope that I get similar battery life as I was getting with gingeritis 3d VI.
Both gingeritis and bamf are pretty snappy.
Is there any way to change the ring unlocker to the regular slider? I try to snooze my alarm clock but can't figure it out lol i like the old way
So I have cleaned up my card, and it seems that whenever I run gingeritis I get force closes on the gtalk and the camera still I have done fresh installs and wiped. Seems like I am the only one having this issue. I guess I will stick with BAMF.
I noticed same problem this AM no camera working on my TB. Is there a perm fix, without having to disable automatic date and time?
dowload the camera.zip file
I Installed ROM from sd card. via ROM Manager or you can do it in Recovery
Flash this http://db.tt/Bcltlcr I take no credit, Snow02 posted it over at BAMF, it works.
Yeah I mounted the camera.zip and wiped. Worked like a charm. Not needing around with any more roms.
Rooted my thunderbolt earlier today and installed this as my first rom. I flashed the possible end call bug fix but got my first end call bug just now. Sucks.
Yeah me too. Had one last night.
Sent from my Bolt via Tapatalk.
My google talk keeps crashing. I was running version VII great until yesterday and my talk started crashing. I said "well now is a good time to upgrade to VIII." I did a complete wipe and a new install of VIII and I'm still getting this error as soon as I open talk: "The application Talk(process com.google.android.talk) has stopped unexpectedly. Please try again". My only option there is force close. I tried clearing the data and clearing the cache and neither have worked? Could there be something buggy in my google profile? Seems strange to get this force close right after a fresh install of a a rom.
Before I flash this. I am running Bamf 4.9 with some sort of radio installed (been a while since i flashed) Do I need to install another radio, or should my current one keep on working?
Follow the fix a few posts back about disable automatic time and setting date back.
The date time trick has to be done every time you reboot. You want this.....
http://themikmik.com/showthread.php?t=8434
Reactions: sloan31
Sorry for noob question but how do I flash this fix? Download to SD, don't rename and flash with ROM mgr? Thanks for any responses.
off8485
