[ROM]GingerSnap 2.3.8 10/25/12| 2.2 Rebuilt to 2.3
Re: [ROM]GingerSnap 2.3 Special Oct17| All in One LG+CM7/GinDX
@thatguy--- dont forget you can trash the xt9lib too... (unless you already did)... :-)
I forgot about libs! :P
I usually sort them out by size, figure out what they are, then delete them :)
Thanks Cloud!
@Everyone, Have you guys been having trouble with Tapatalk alot? When clicking sometimes, you get alot of " Failed to Connect " stuff.
Yes, it isn't ROM specific. Running CAI-CM9.
Cool to see you got 2.3 ported. Sadly I won't be able to try it, see my Sig for details :D
Sent from my HTC One V using Tapatalk 2
I've been using this ROM since the latest update, and just today, I tried to update Facebook, and got the dreaded "Insufficient space on device" error (total BS!). Then my browser was being slow, so I was going to install dolphin, and got the "package file is invalid" error. WTH? Should I be using different gapps? I flashed the one from page 1, but there was no market/play store, so I flashed another GB gapps that I used with another ROM. What do I do? I really like using this ROM and I don't want to switch, but if I can't update or install anything, I'm left with little choice.
Use Gapps below, and Read below, and I recommend 2.2.
I rcommend 2.2. 2.3 is laggy.
You already know ;)! Its based off GingerDX!!!! So JellyBean TaskBar is included in settings!
Rom: http://db.tt/o9Oliapi
New Gapps(By me): http://db.tt/em68x0FO
Based from latest CynogenMOD nightly 2012-10-14
Build Fully ported LG 2.3.4 MDPI launcher, better widgets spacing, no more stiffness, lighter
Added new command "zip" run on terminal emulator: function manually zip align your apps, use this after installing several apps to improve memory handling and boot time.
Reverted the stock android Email application, LG mail crashes sometimes
Re-introduce ported lg 2.0 keyboard preview - working user dictionary - working keyboard hapticfeed back - fits screen - fully functional
Ported LG stock music player Fully ported
LG 3D music social widget sizechangeable preview
Ported LG o2x social networking service, now you can have fb myspace twitter on app drawer, you can use under any other launcher + 2 new widgets /social feeds and my status Ported widgets from
LG 2.0 stock roms, favorite contacts widget, power control, network usage etc..
Ported stock LG Movie player (better playback) supports subtitle
Fully working polaris office viewer from p690
Ported LG stock calendar app preview
Ported LG Richnote APP + widget sizechangeable preview Modified SMS app close to stock LG - multiple contacts selection - bubbled style - quick buttons, single contact avatar view - LG messaging stock layout - pre default settings have been configured
Merged Mik's Camera exposure mod, better default exposure levels
REVAMPED messaging widget, NEKO'S Personal TOUCH
Added LG wifi-cast, now you can share files trough wifi, function? read here
Updated LG cosmetics almost anywhere, source from p900 and p690
Fixed white dialer buttons when Russian language is selected
Fixed battery drain issue - google apps related
A lot of changes features and ports.. see for your self..
ISSUES: If you dont like the LG MDPI launcher, download the old LG launcher from 2.2, link below, flash through recovery
LG launcher does have issue on category and list style, use paginated layout works flawlessly. FC when tapping add favorites on Favorite contacts widgets, TO add fav contacts go to Contacts list and select fav contacts, it will show on the widget. FC when selecting more > sound effects on Music player, shortcut not working even on black bird ROM FC when pressing comment box on 4x3 lg music widget, it doesn't work yet, not needed at all twitter and myspace works
This Changelog Probably came out nasty looking, I will fix soon!
Battery life with removed APKS. Always with the music too :)
I will now start charging.
TGL
Per my PM. Here is screenshot with the removed apks.
I ran it all day yesterday, charged twice through the day, then charged overnight. Within the first 2 hrs it was down to about 80 which granted is not that bad. However 2.2 on my phone wont go below 80 for at least an hour more.
I gave it a shot figuring i was playing a lot yesterday, but by 11 am est i switched back to 2.2 and my batt is now holding strong
Trust me i definitely want the newest ?best? gingersnap there is and imo 2.2 is where its at right now
To each his own though :D
Almost 4 hrs and still at 86 on 2.2
Wow!
Is that 2.3?
What all did you remove?
I have been running 2.3 for about 2 days now. I used Link2SD, though you could use other program, to freeze (as opposed to deleting at this time) the following apps:
Browser.apk (I use UCbrowser)
DeskClock.apk
Email.apk
FavoriteContactsWidget.apk
Protips.apk
LatinImeTutorial.apk
HIME.apk (I use ICS keyboard with no issues)
GenieWidget.apk
PhotoFrameWidget.apk
RichNote.apk
RichnoteWidget.apk
SNS.apk
Superuser.apk (I use SuperSU)
Talk.apk
UserDictionaryProvider.apk (I use ICS keyboard user dictionary)
Wi-FiCast.apk
Items listed are ones I have frozen (disabled). I understand some users may want these, however, they do not affect my use. I have been running today with moderate use.
I'm going to work on a Debloated 2 e now. Removing Things like Weather, Polaris, SNS, and so in. I'll be making a zip for those to be flashed :).
Looks good, i am impressed
Ok. This one is NOT based on GingerDX. I found that the one on the blog is based on Gin DX, and the one on thread is CM7. The rom is now 98MB, without new kernel included&being ported yet(Lets find out what the actual one is), and I got permission from EarthnFire to use his kernel in the rom. :) Hopefully this has better battery life. I'm going to leave SNS in this one, see how it going, but if it drains battery, delete it. I play on adding things still as well.
Re: [ROM]-GinerSnap 1.3|7-15-12|Stock LG UI!
How are you porting the ROM are you using Android-Kitchen to do so, or some other program?
New Rom is uploading. Rom is 95MB's, and I made a SNS( Social Networking Service? ) zip, along with a new updated Gapps by me. :) It will also have a modded build prop for Beats, and Sony's Xlound, and so on.
Okay.
Just for kicks I unpacked the boot.img and noticed that the lowmemorykill files are not written, this could also be part of the problem with battery usage. The OM kernel has lowmemonykill treaks built in, but the file needs to be written in order for the kernel to know when to kill running programs.
You can also try removing some of the languages within the apk's this well help with the size of the ROM, though you will have to resign the apk's the in the ROM with the right key.
You just made that sound soooooo easy!!!!!! I never understand how to unpack a booot.img. I don't understand what they talk about and what to use to do it.
I added the kernel by using the update script to flash the kernel when flashing the rom. Does that make the Lowmemorykill files written?
It's part of the boot.img, I can go through it two and add what needs to be add for you.
edit: Okay so the lowmemorykiller is there, it is just set to low for our phones.
Code:
# Define the memory thresholds at which the above process classes will
# be killed.  These numbers are in pages (4k).
    setprop ro.FOREGROUND_APP_MEM 2048
    setprop ro.VISIBLE_APP_MEM 3072
    setprop ro.PERCEPTIBLE_APP_MEM 4096
    setprop ro.HEAVY_WEIGHT_APP_MEM 4096
    setprop ro.SECONDARY_SERVER_MEM 6144
    setprop ro.BACKUP_APP_MEM 6144
    setprop ro.HOME_APP_MEM 6144
    setprop ro.HIDDEN_APP_MEM 7168
    setprop ro.EMPTY_APP_MEM 8192
# Write value must be consistent with the above properties.
# Note that the driver only supports 6 slots, so we have combined some of
# the classes into the same memory level; the associated processes of higher
# classes will still be killed first.
    write /sys/module/lowmemorykiller/parameters/adj 0,1,2,4,7,15
    write /proc/sys/vm/overcommit_memory 1
    write /proc/sys/vm/min_free_order_shift 4
    write /sys/module/lowmemorykiller/parameters/minfree 2048,3072,4096,6144,7168,8192
This is what mine is set at be default as part of OM-Mandylion
Code:
    setprop ro.FOREGROUND_APP_MEM 3584
    setprop ro.VISIBLE_APP_MEM 4096
    setprop ro.PERCEPTIBLE_APP_MEM 6144
    setprop ro.HEAVY_WEIGHT_APP_MEM 6144
    setprop ro.SECONDARY_SERVER_MEM 38400
    setprop ro.BACKUP_APP_MEM 38400
    setprop ro.HOME_APP_MEM 38400
    setprop ro.HIDDEN_APP_MEM 38912
    setprop ro.EMPTY_APP_MEM 48640
    write /sys/module/lowmemorykiller/parameters/minfree 3584,4096,6144,38400,38912,48640
Nazeer zaheen
