[ROM]GingerSnap 2.3.8 10/25/12| 2.2 Rebuilt to 2.3
Re: [ROM]-GinerSnap 1.3|7-15-12|Stock LG UI!
I am testings today's newest version right now directly from GTR Reloaded. I love the boot animation!
Re: [ROM]GingerSnap 2.3.5 Oct 20,12 | LG EXP3RIANCE!
Tell me if you have root. Mine says Su bin not found, so I'm wondering if its something I did.
And I also still cannot download anything from the Play Store larger than a MB without getting "insufficient amount of space" error or "package file is invalid". I had that on GTR too. Any idea what's wrong?
Band Geeks Rule!
Remove the 01mvdalvik script from the /system/etc/init.d folder. The script moves the data/dalvik-cache to the cache partition which is a small partition and fills up quickly.
Band Geeks Rule!
Do you have a Partition? If so, that could be somewhat of the problem...
I'd do Earthnfire's advice first.
Did you do a full wipe?
I have to work on a root fix now. I want to get the root working at boot. It says " Su binary not found ".
From past experience, I know that when I add superuser and the Bin file manually, it results in a fail root. :/
No partition. No full wipe. I just cleared cache and dalvik cache. Can I just root again with Ginger break?
Band Geeks Rule!
That's probably why. What did you upgrade from?
And, I'll post a zip in a minute to gain root again.
Still 2.2...going to flash the new download soon and check it
Look at the Battery near the end. Went from 29 to 34, no charge.
Look at the drop though c.c
My phone is so faxed up, it reboots 5+ times a day on its own, or while I'm typing.
Thanks for the update!
Is it possible to get the LG Keyboard back again? Maybe optional package? I really like it and I had no lag issues. I tried restoring it with titanium backup but it just FC's :(
Edit: I even copied HIME.apk to /system/app/ and set permissions, but it still FC's what am I missing here?
Thats faxed up!
Broken links on 2.35 and gapps
Just flashed and I cannot get root access.... didnt do anything differently than I normally do.
Ill post a zip tomorrow. I just got home. Its missing the XT9 core, and some folders and what not.
Ill take a look :)
Ill post a zip for root under the rom, idk why root disappeared though. Say Missing Bin file.
That's probably why. What did you upgrade from?<br />
<br />
<br />
I upgraded from GTR. And thank you.
Band Geeks Rule!
DL?s in changelogs work
In the download section they dont work on my mobile
Are you sure? I clicked them on Mobile via Tapatalk and it went to Mediafire. :/
SophieTurner
