[ROM]GingerSnap 2.3.8 10/25/12| 2.2 Rebuilt to 2.3
Re: [ROM]GingerSnap 2.3.5 Oct 20,12 | LG EXP3RIANCE!
DL for rom in DL section does not work. Other links appear to be okay
Sent from my LG-VM670
They all work from my PC so I don't know wtf
Got em though so all is good:D
No ;(
GSnap test - No Wifi! Need to do something with Modules in ETC.
MIUI - Still Phone FC!
I'm working on that still as well. Gotta trim it more still :)
10-20-2012 GS is working great. Probably the fastest ROM that I ever had on my OV. Thanks for your work!
No ;(
Miui GB?? Is it different then Johnny's? Or is it Miui 4.0? Just interested!
No rotation lag, no FCs, MMS, just Phone FC. I plan on ffixing it when I get home. Found a common fix.
love 2.2 on 2.3 my battery dropped to nothing in less than 8 hrs...I wasnt hardly on my phone at all it was just sitting all day for the most part..so back to 2.2 I went
This is mine o_o
2.3 first full day, not even close to 2.2
I did use navigation for probably 30 min though and was a bit more active than my 24hr battery result on 2.2
I'll give it another day till I make a final decision :D
Testing the MIUI. Hopefully you get everything sorted out with V4. :3
Edit: Is the Phone FC the thing that's keep on popping up each time I do something with the phone
Just found out your using the om kernel!
Nice:D
Hey, I'd like to use this on my optimus s. I think this is an excellent rom and it's beautiful. I do a full wipe, install the rom, reboot, install corresponding gapps and reboot. I don't get network, try the fixbb get error about baseband files not found. I apply the ls670 kernal, reboot again, fixbb still doesn't help. I would really love this for opt s. Help! :confused:
Sent from my LS670 using Android Central Forums
That's gotta be a record! Lol
@t2igg isn't there some kind of patch you would need to flash after the v rom to get data mms and keys switched for the s?
See if this helps (LS670-kernel version of VM670-OM-Kernel with GingerSnap's build.prop edit for use for Sprint.
Heh. Earth beat me to it :P
I had a day today. Got baptized. Feeling good :)
Does anyone know how to read Log cats? I was to see if I can get a log at from my phone when it freezes on 3G. Happens 2-5 times a day. Rare on wifi. Once every 3 days.
mcheck
