ARCHIVED: [ROM] - gROM 2.2 - 10/16 - GB - With Flash - Yes, FLASH!
Status
Not open for further replies.
Re: [ROM] gROM 1.1.5 - 9/27/11 - GB 2.3.3 - Lets Rock!
Is the battery life a lot better than the stock? Debating whether I should bother, thanks!
Grr. My lockscreen is not coming on when the screen goes off. When i hit a button to wake phone i get home screen and no lovk.
I've been getting a "Google Talk authentication failed" since I loaded the rom. Also, the stock power widget bar shows up but is just blank.
I just reflashed the ROM and I'm not getting the "Google Talk" Error any longer, however the stock power widget still has the blank issue.
Install the power widget to your screen, then reboot. It works.
Digging it!! THANKS!!
Any luck with WiFi Hotspot? (not wifi tether)
Music refuses to play because the music app doesnt notice I have an sdcard plugged in, cant use music as ringtone because even rings extended says I have no music. Every time I press the home button it makes me re-choose the default launcher to use. Giving Optirom a shot.
On the plus side it now boots in about 5 seconds.
Loving the rom just have one thing. Sometimes wen i press a batton to wake the phone it wont wake. Ill try allvthe bartons an nothing will gave to wait a lil bit an try again or pul batt. Not whats wrong or what u did.
Anyone having lockscreen issues? I just don't like having an unlocked phone when I hit the power button to turn the screen off, then turn back on and not have the lock screen.
Haven't had any. Using 1.1.5 now but 1.1 worked fine for me as well.Just annoyed over the kernel issue lol. Had problems loading OptiRom as well, since the kernel is built in, to try it out. But i finnaly got it to work after a few reboots. Seems very quick with the OCing but once i soft reset never know when it will work or not. But for some reason cannot get the kernel to work with stock or grom at all. thinking its a hardware issue maybe older phones have this problem.
For some reason the Ad blocking isn't working for me in 1.1.5, it worked before. My hosts file is definitely not empty. What can I do?
No, not yet. Have you tried the latest WiFi tether? Its hot spot capable. I have not had time to try it but use it in my Evo 3D ROMS and peeps love it. Give it at try and let us know!
Sounds like you got something installed that is not co-operating very well, lol.
Not sure on that one.
Nope, not seen it.
So go to a site like... ummm... any with ads... Choose desktop UA and tell me if you see any ads.
Is there an oc kernel for this rom?
Im working on one. Some say that GK4 works ok but... I have not tested that yet so you are on your own if you want to try it. Good luck!
-Scott
Thats why I asked rather than just tried one...
WiFi Tether for Root Users - v3.1b6 supports infrastructure mode + WPA2, although it crashes your phone (reboots) when you try to stop tethering... Otherwise good speeds and faster than the native tethering (also it is much faster to get a DHCP address compared to the native tethering)
-Scott
I've used the wifi tether. I was looking for a non adhoc wifi like the native (disabled) hotspot.
But have you tried the latest one...
Its infrastructure mode now. I use it in my Evo 3D ROMS and people enjoy it. I have not had the time to try it on Optimus S yet but it should work.
Status
ahmedhadeethy
