ARCHIVED: [ROM] - gROM 2.2 - 10/16 - GB - With Flash - Yes, FLASH!
Status
Not open for further replies.
Hi, I'm semi new to android central and the optimus s but i've had an optimus v before and several other android phones.
I wanted to say I have loaded gRom2.2 and everything is workng well. My screen will double tap kinda often, I'm thinking I might have to lower the mhz down closer to 700 instead of 729 (opinions appreciated...lol).
This ROM seems good, I like this phone/ROM combo A LOT MORE than my Evo.
Just out of curiosity: is there a way to get a larger top bar? (where the time/battery/cell meter lives)? :)
Hello out there. I was just wondering if there was a way to get wifi hotspot or teather working? I read somewhere on this thread that one in the market works. I'm sorry if I missed it being mentioned already, but is there a fix for this, or what app works? I updated my girls phone to g rom and she uses
hotspot for her clients at work, so I'm in the dog house right now. Somehow I didn't realize it was broke. Any help is appreciated. Thank you in advance. -B-rye
Sent from my PC36100 using Tapatalk
Edit: found it. My bad. (in or around post 1091) thanks, later.
Hehehe... That search button will get you every time! lol
Quick question -
I just installed gROM on my wife's Optimus.
On bootup - after the LG logo, her phone has a blue android robot with a circling flame. My phone has the word Android with different shades going through it.
I'm pretty sure that I used the same files for both. What's causing the difference?
You did not install the same files. The one with the AOSP Android Logo is older version.
WiFi Tether doesn't work for me. I downloaded Open Garden WiFi Tether and then it worked. However I want the Original one to work because it might be able to let me connect my HP Touchpad to my phone via infrastructure vs ad hoc.
Is there a reason the original on gRom doesn't work?
Thanks
WiFi tether works great. The one in the ROM provides both infrastrcuture and Ad-Hoc mode.
I think b-rye mentioned that wifi tether was discussed around post 1091. I know it has been discussed before here. Try searching the thread. I just use Wifi tether from the market and it works fine for me.
6 to 1 or a half dozen to another... lol
Yea, maybe one of the theme devs here can make the top bar bigger. I am not so sure how to.
-Scott
Scott -
Which files were different? The gROM zip? Is the newer one worth updating my phone with?
( I found the gif on her phone)
-Scott
Kewl, thanks. I'll have to check it out, I took the phone off charger at 6am and left it alone until 7pm and it was at 94% battery...thats pretty darn good considering I'm not in a real good signal area.:D
i was trying to put power control plus in my notifacations bar ,i rebooted g rom but the application just deletes my widget could it be a bug with gingerbread
Yeah, thats too good actually. Very strange because I can only get numbers like that when I shut off my 3G. lol
Could be! Post a market link to the app and i will try to play with it.
To make yet another addition to the thick binder that represents my bug reports:
DSPManager frequently crashes when an outgoing call is made. Pretty much every time. Never on incoming calls though.
Scott,
Thanks for the great ROM, I've been using it religiously since you dropped it. I tried opti-ROM, but returned to gRom just because it's so much better.
Is there any chance in a future update that you might be able to do something about the VOLUME issue with GB on our phones? I have my volume all the way down, and my ears still start bleeding when I get calls. When I try to use speakerphone, I can hear myself echoing it's so loud.
Is this something that you would be able to correct, since Sprint couldn't/wouldn't fix it?
3G and sync both on, wifi BlueTooth, GPS off. But bear in mind it was just sitting on the desk whiles I was at work. Brought it to work today, only checked it a few times and I'm at 77% but I did NOT charge it since yesterday at 6am. I couldn't be happier. :D
Scott,
I've found that doing the following once after a reboot fixes that until the next reboot: when in a call (or Google Voice listening to a voicemail, etc.), turn the in-call volume all the way up, then back down as desired. I do agree, however, that it would be nice if that wasn't needed :-).
Scott,
Love gRom great work........has anyone else seen a problem with the sd card unmounting itself when charging with a/c charger......didnt seem to happen when i was using cm7 but dont want to return to that because of the older sprint radio's my data now is zippier as hell.......also under the battery status tab the battery info at the top with the graph letting you know how long you have been on your battery seems to be broken for me........other than these minor issues for me great rom
any chance of making a full blown Ice Cream Sandwich theme for this neat rom....:):)
Hi I like your rom but I can not get voice mail notification.
Do you have some solution to this?
I use grom 2.2 now on pageplus. Everything is good just no notifications for voicemail.
Scott,
Yeah the battery indication issue you noted has been noted before. It is what it is. I did the best I could with what Sprint gave us (then pulled from us, lol). IF they ever update again.....
Not so sure on pageplus settings. I am sure there could be a difference. Not sure though. Sorry...
-Scott
Reactions: bamakore
Scoot. I'm getting gnarly taps on my screen. To the point I can no. Lobbgeer add or remove Widgets. They just open nooww. Hardly scroll myy app list. This is at 600mhz usingg smartassv2. Data2eext, a ton of apps and preetty. Much everythingg else stock to the rom. Any ideas? I've cleared cache but no help. Trying not to refllash rom. Started about a week aftter instaalling rom.
Might be your kernel. I had bad screen issues on the Drew's original kernel. Give stock LG kernel a go.
Status
corneliarphillipis
