ARCHIVED: [ROM] - gROM 2.2 - 10/16 - GB - With Flash - Yes, FLASH!
Status
Not open for further replies.
Ondeemand is stock setup. No difference. Flashing stock kernel kkills data2ext. Ill try an older kernel and see if I can get anywhere.
I can do a stock kernel with data2ext if needed. LMK.
As far as why its happening now vs a week ago when you installed... No clue! lol LMK what route you want to go and I can help.
If you could tthat would be great. None of drew's older kernels made a difference.
Anybody notice that using gROM the camera takes really crappy pics? It seems like they are more blurry than at any other time. And especially if you zoom at all, any zoomed pics are basically worthless. I don't know if the ROM can affect this or if its my phone, but my pics all look fuzzy or out of focus no matter what settings I use. They were not like this before when I was using ReBorn....
Planning on trying out YOURMOMROM tonight anyway but thought I would throw this out there...
ok i am having issues using this i loved how it looked in the pics, but on my phone it's just not looking right, idk if i did something wrong, also would anyone know why i am unable to use the wireless tether?
Gingerbread update delievered by Sprint has "camera improvements". This rom is based on that Gingerbread update. I did noticed yesterday that I cant take pics in low light anymore. Looks like enhancements actually means the opposite.
Post pics
Read thread. Multiple posts instructing how to use wifi tether. Second option is to download the one from the market. I use Open Tether. Just works, no system crashes after disabling.
For some it has to be configured. Under device profile choose Optimus s. Under setup method, wext is for adhoc and nedt is for infrastructure. Nedt will crash your phone when tether is disabled so unless you need infrastructure mode choose wext.
i have noticed the camera takes blurry pics to what i did to fix it is mess with the auto focus i press the camera button on the side till the white square pops up when it turns green fully push the camera button it will work with zoom too if you notice the camera button on the side seems to have to positions when you push it you barely push it and a white squared box will pop up when it turns green its focused and it will take a clear shot if its red it will be blurry
and ive noticed with the new gingerkernal v07 it seems to me that it fixed that camera blurryness you only have to push the button once and it auto focuses great
Well then looks like we found a simple fix!
I plan on updating this ROM with the new kernel later this week. I am going to do 2 version. An apps2sd version and a standard version.
sweet i will be updating then i have your gROM 2.2 file flashed then i flashed the ginger kernal v07 and it has fixed the camera focus issue before if i took a pic i would have to basically use manual focusing with the new kernal i can just snap the pic it auto focuses fast too
got a question my phone does these random shut offs i have my oc to min 245 max 729 could it be too high or too low of overclocking could that be why it is shutting down on me
if you are using the new kernal drew took out over clocking abilities that are in between 600 MHz and 729 MHz ... i suggest you backup all your apps and do a full wipe of everything and then reinstall grom.. and then boot it up configure everything and then go into recovery and wipe cache and then instal v7 of drews kernal and over clock it at 768 with the interactive x governor and deadline scheduler... thats what worked best for me anyways...
No, its got to be something else. Possibly an installed app? Have you tried to wipe your cache's clean?
i need help, i put this rom on both mine and my girls phone but hers doesnt have the wifi tether app and i cant find it in the market
Status
affansahab2021
