ARCHIVED: [ROM] - gROM 2.2 - 10/16 - GB - With Flash - Yes, FLASH!
Status
Not open for further replies.
Hey Scrosler do you think on the next build you could make Swype removable so we can uninstall and put the newer one on that works better. Just an idea.
Correction: It seems i still have doubletap issues, just much less frequently.
Everything else is still working though
Has anyone had an issue with headset and speaker volume after installing this ROM? I just rooted my wifes optima and she loves the ROM but says her volume is a lot lower than before
Thx
Yep, it works well. I did some prelim testing for him last night. Found no issues. I will update this ROM with some goodies this week!
I've been loving this ROM, and I just put it on my wife's phone a couple days ago and she's lovin' it too. Thanks :-D.
I just wanted to ask in case you hadn't thought of it: Are you planning to update Flash to 10.3 with gROM 2.3 (or whatever)? I noticed that's out, and I've heard performance can be considerably better than 10.2.
Thx
You can use the DSPmanager, in order to boost sound output.
It'd be cool if you added the extra bluetooth protocols like they had in the CyanogenMod. Otherwise, great ROM and no major issues. Thanks!
While in a call and using Speakerphone I am not able to adjust the volume. It is full blast and straining the speaker. I tried to use the volume rocker to lower the volume and it doesn't work. Any suggestions?
Also I am getting phone internal memory low. I tried app2sd but it seems that I still am so close to the limit. Do I need to erase emails and txt mesages to get more space?
Otherwise works great and fast!
I am unable to flash the ROM onto my phone. I am rooted with custom recovery. I get the error: can't open /sdcard/gROM_2.2.zip... :confused:
I did, it completed without errors. I was able to open the ZIP on my machine and then was able to open it from the root of the sdcard. When I boot into the recovery and chose to install, it gives the error. Then I connected the phone back to the PC and tried to open the .zip file and got an error stating that the .zip was not complete and to add the last disk if it was part of a spanned .zip file. I tried to open it once more and everything was removed from the .zip file for some reason. I am downloading it again and will try it once more. Thanks!!
I re-downloaded it and it has been flashed. Thanks for your help! I just got the phone back from repair, the screen had to be replaced and they updated it to the ZVH version. :)
Status
Algarañaz
