[ROM] Harmonia 2.09 18July12 (IHO Gingerbread)
Re: [ROM] Harmonia 2 (IHO Gingerbread) See first post for updat
Leslie where can I find the V6 Supercharger I cant seem to find it anywhere. Awesome ROM btw :)
Reactions: fstmstngs
I'm thinking it was just the build.prop left over. I'm not sure.
I saw the settings for it in the build.prop but I have never used it before so I have no idea what is or is not there.
Oh ok thx Leslie this is my favorite ROM ever :cool:
Edit: Ohh thx Andy ill check it out right now woot
I'm only passingly familiar with V6 Supercharger, so, not in any detail, how does this work? You say that it's pre-installed, does that mean that it's just working out of the box, or does it have to be activated in anyway?
I'm waiting to hear back. it may be left over settings or it may be installed, I'm not sure yet.
Hold off downloading for a few, I made a mistake in the build.prop which will limit what you can download or restore to your phone.
I will have it corrected shortly and I will have a rom and a patch.
Reactions: scootincivic
2.01 has been taken down.
No matter what I do to the build.prop, Google refuses to see the phone as it should. This results in certain apps not being available to download or restore.
If you already updated you are fine, but you may miss out on some apps showing in the Market.
As to the question of updating, you can just put it right over the top, however, sometimes you to lose 30 megs or so, sometimes you don't. As mentioned wiping Dalvik, and cache may help, formatting system may as well. None of these should wipe your settings.
That explains why I cant find some apps lol. Other than that so far so good.
Sent from my VM670 using Tapatalk
Google Voice Search
Does Google Voice Search not work with this Harmonia 2? I'm getting a "package file is invalid" message when I try to install it from the market. I use it a lot (crippled up fingers), so it's pretty critical for me. TIA - sheureka
Which version of Harmonia 2?
2.0 had some issues with apps not appearing, but for the most part I fixed it, 2.01 has severe issues with it.
Mrg666 and I are looking into the problems to see if we can track it down.
Reactions: sheureka
I am loving this rom so far, but I found one glitch. When you are in the gallery, it freezes up, and reboots my phone. Is this just me or is anyone else having this problem?
I've been fed up with the performance of 3DGallery for a while (I had major issues with it on Android 2.2, how slow it would load thumbnails, using up all my battery). You should try QuickPic, it has a much cleaner interface, in my opinion, and it loads the thumbnails and images much faster.
I have Harmonia 2 GRJ90 - thanks! - heurea
Agreed. Quickpic is a necessary app in my opinion.
Sent via VM670
I had this issue with another Rom I solved it by partitioning my sd card and installing links2sd
I don't understand what's wrong with 2.01. Its great. I have no problems. Or is it for some people?
dumpsterrentals89
