[ROM][ICS][Aug 18, 2012] Android Open Kang Project [Stable 4]
Status
Not open for further replies.
Re: [ROM][July 30, 2012] Android Open Kang Project [Stable 2]
nice! thx DK for the work! im on the latest xda build! time to jump to stable 2 until JB rom is ready! appreciate it!
I'm looking for something along like a bluekuban rom cam. Especially with video giving me the full screen to view while recording
Sent from my SPH-D710 using Android Central Forums
Then get blue kuban ;) or a market app..
How can I go back to stock ROM?
I need to go back to stock ROM for a few hours.. I had the manual ics update. Zip on my card and thought I could use that but apparently I can't
I coulda told you the ics zip wouldnt of worked. its a system patch for el29 to ff18 only. not a full rom.
Ok.. What do you recommend?
Temp flash el29. Google it. I do it all the time to uodate profile or enter key codes.
OK finally flashed it successfully getting signal once I booted there was none until I changed roam settings from home to automatic
Here's my problem. Is anyone else experiencing low volume when listening voicemail. Using youmail. Even installed a sprint vvm and same result. Extremely low while playing VM.
I had that too.
Sent from my SPH-D710 using Tapatalk 2
Status
sukarisw09
