[ROM][ICS][Aug 18, 2012] Android Open Kang Project [Stable 4]
Status
Not open for further replies.
Well I for one love this rom. Absolutely no problems here. I have used the aokp there and it was awful. Keep up the great work dark. Screw them.
sent from my BAD A$$ Epic touch
Think dk is talking about cm10 and not aokp lol.
Sent from my SPH-D710 using Tapatalk 2
Re: [ROM][July 30, 2012] Android Open Kang Project [Stable 2]
Anyone having trouble with 4G? My disconnects and then says "Unknown". If I restart it, then it works fine.
I am in bad service at work (though when I do connect to 4g I am getting 10mbps down) , but this is happening allover Brooklyn/Queens, where I usually get good service.
Reactions: Downtown Taco
Same here. I believe it's an AOSP issue rather than a single build. Perhaps DK can clarify.
@Dark have you had a chance to look over my logs a few post back? Just wondering if it's a user issue or bug that is causing my reboots.
Ive lost count of all the logcats ive looked at :(
im thinking about giving cm10 a try.,.... i know last time the sound wasnt working when i got calls... and the vibration is weak... is that fixed?
Ha ha, that's cool. I posted three logcats here: http://forums.androidcentral.com/ep...n-kang-project-stable-2-a-14.html#post2032357
I had two consecutive reboots then a third that followed shortly after. There have been no reboots since these occurred. No worries if you don't have time to look into the issue since I know your plugging away with JB right now :) Thanks.
This is not the CM 10 JB thread :) I believe those issues were squashed; though, you'd need to check that thread to confirm.
Is there a way to get the torch to work when the screen is off?
Also, how do I make a log? I've had a few random reboots. Other than that, smooth sailing and amazing battery life/stability.
Sent from my SPH-D710 using Android Central Forums
Instructions for a logcat are in the first post.
Does this ROM have a safe kernal included? I've flashed a lot of stuff from recovery already. Just wondering if I should use more caution. I'm running build 1 btw. I know I should prolly upgrade to build 2 but haven't had any problems so far with build 1. Thanks
Does this ROM have the safe kernal included? I've flashed a lot of stuff from recovery already. Just wondering if I should use more caution. I'm running build 1 btw. I know I should prolly upgrade to build 2 but haven't had any problems so far with build 1. Thanks
Yes the kernel is safe. No bricks reported.
Reactions: WhoAmI and JWnSC12
Sorry if this has been asked but at work and can't read through entire thread right now. Is there any fix for computer not recognizing phone? I read its a known aokp issue, just looking for a work around
Ya thats a aokp issue in general. no known fix.
Hey DK, do you build your GPS fix into your AOSP roms by chance?
Status
taoujdate
