[ROM][JB][WIP] CyanogenMod 10 for LG-P505/506
I found the NewBBfix_signed.zip earlier in this thread, but when I used it the settings page still said the baseband was unknown and the cell radio wasn't working.
Sent from my LG-P505 using Android Central Forums
Well, it worked for me, so I don't know what to tell you.
Sent from my Amazon Kindle Fire using Android Central Forums
Did you wait? First boot takes a while
Yeah, apparently that was my problem for that error. Unfortunately I still don't have cell access. I tried reinstalling the baseband fix that I mentioned above and it still isn't working. I can access wireless, but not cell. Err...
The new baseband patch should be flashed after the ROM. I hope you're not following my previous advice about flashing the kernel I attached to a previous post as you won't need it with the patch. Also make sure that when flashing that you wipe everything, ie; factory reset, dalvik cache.
Here's the steps I followed:
Wiped cache / data / dalvik cache
Installed the CM10 rom
Installed the baseband patch
It's usually good practice to reboot the device or the recovery between flashes. I normally just reboot the recovery if I have several zips I want to flash.
From the CWM home/main screen select 'Advanced' option, then select 'Reboot Recovery' option.
Great News!
Most of my ROMs are on ROM Manager
Under Rashed's ROM's.
Also the Google Apps Light package is there too
EDIT: No the GAPPS aren't...
Here is the link to it: http://d-h.st/HGc
I gave up and flashed the 7/30 p505 ROM and now it's working. Can't wait for the next update to the p505 though. So far I've found that (in addition to what's already known and mentioned) both Pandora and Voxer don't work.
And this latest build won't fix it either....
I have NO IDEA what is wrong... Maybe they don't support JB yet because all audio works perfectly...
Anyway, August 5 builds are here!
LG Phoenix (P505)
LG Thrive (P506)
And I would really prefer is people look at this as well:
[ROM][4.1.1][CM10][UNOFFICIAL]LG Optimus One Family CM10[August 5, 2012: Build 2] - xda-developers
I own that thread so I update a lot and I'm there more than here now ;)
All downloads will be made public there first, after ROM Manager of course :p
i tried out the 8/5 build and i couldnt get apollo to work from what you told me last time force stop then clear data. it i didnt work so i went back to the 8/1 build.
Strange. Apollo works for me :confused: In fact, listening to music now with it.
we get roms on CWM but not a recovery? also you have to get the paid for version to get roms yeah?
Yeah, I have to classify them as P500 ROMs to show up. As for the recovery, we're working on it. No, you don't have to have a paid account. The ROMs show up in Premium for 2 days of the week and free for 5
i think that you need a update on this post and talk about what work and not work... i rhink that the hard field is the constante scrash app...
dumpsterrentals89
