[ROM][July 23, 2012] AOKP Milestone 6 [RC5] AOKP/CM9 [Nightlies]
Status
Not open for further replies.
I tried the custom recovery but it would not recognize the folders.
Sent from my SPH-D710 using Android Central Forums
Mr. Batman sir I love you for this rom. RC5 has no flaws that i can see as of now. My Android OS percentage on times infinity's build was almost 40% always and with your RC5 its at 5%. Battery's great and phone isn't overheating at all... I think there was a slight screen tearing when I first flashed it but it's all gone now. I'll report back if I see any other problems. Thank you and put up a donation link! :P
Sent from my SPH-D710 using Tapatalk
Ya ive been getting that request alot. I will put a donation link together hopefully today. Remember im not doing this for donations :) I was just sick of waiting for a stable Aosp type rom. We are very close. Next build will be "S1" for Stable One. There are two more upstream bugfixes I want to add and i will dig thru new nightlies source to see if there are any new bugfixes as well.
Yes I don't think I did it right let me try YouTube.
I was being stupid.
Button and the little option had me mixed up. -.-
Re: [ROM][July 23, 2012] AOKP Milestone 6 [RC5] AOKP/CM9 [Nightli
Ok, will do. But can you upload this file from your kernel? It's located under /arch/arm/configs/ It's the TARGET_KERNEL_CONFIG variable. I think it should be like cyanogenmod_(devicename)_defconfig
Thanks in advance.
Thanks in advance.
The kernels im using are either chris41g. Stock ff18 aosp repack. Or Times_Infinity kernel. Not using mine as of yet.
Will we ever see AdHoc support for wireless cards in AOKP/CM9 builds? I remember my evo 4g had it in CM7.
Does anyone know if this is a planned feature?
Thanks
AdHoc should work. I wouldnt see why it would not work :confused:
I can never see the networks when I create them in Windows or Linux. If someone has successful created and connected to an Ad Hoc do share please! :)
Thanks
I'm having issues with rc5 and the screen not rotating
Status
