[ROM][July 23, 2012] AOKP Milestone 6 [RC5] AOKP/CM9 [Nightlies]
Status
Not open for further replies.
Anyone having issues with receiving mms?
Sent from my SPH-D710 using Android Central Forums
If the screen turns off it stops retrieving -.-
I was going to attach pics but the number shows :/
I fixed Mms issue in RC1 weeks back. Try clearing the app data for messaging app in "Settings" "Applications" then boot into recovery and wipe cache and dalvik cache. Then reboot.
I'm just going to do a nandroid and factory reset
I'm not really having issues receiving mms but for some reason it just doesn't send the picture.. maybe if I try a 3rd party app :(
Does it say sending...
My message has been like for two days already buy they do get sent
Yeah sometimes data gets stuck for some reason. When it happens to me I just reboot and it works again.
Yea it does.. says "sending".. so it works?
I'm guessing not buuuut, is there any known way to modify or remove the ugly white Google search bar? I hate it and want to punch it right in it's tiny searchable face!
Not that I know of.
Sent from my SPH-D710 using Tapatalk 2
DK...GPS on RC4 is nowhere to be found. Apps like Google Nav, GPS Test, Run Keeper and Waze never acquire GPS.
Anyone else having GPS issues.
Re: [ROM][July 23, 2012] AOKP Milestone 6 [RC5] AOKP/CM9 [Nightli
Since I loaded cm9 and now that I am running aokp m6 rc4 my GPS actually works and it hasn't lost signal once. I have been complaining about the Gps on this phone and actually went back and forth with Dark_Knight2 in other threads about the topic. Very happy now. That was the only thing I did not like about the phone before.
Do you think for s1 or next build can we get the voicemail app back
If not any that are recommended
I'm running RC4 still and GPS is flawless. Must be something going on at your end.
Anyone else using navigation bar? At first I thought it was dumb and pointless since we have capacitive buttons and it takes up screen real estate but then I tried it and realized the buttons disappear when you are watching a video or playing a game which is awesome, and they are very responsive.
I turned off my stock key backlight. It's nice having a recent apps button as well. Not that waiting an extra half second to press down the home key was that bad but still...
Should I wipe data, cache and dalvik on RC4...or only the later two?
I guess I really don't understand where the GPS firmware/software sits.
Go back to stock ff18, get a solid gps lock then flash rc4 or 5. That should work. Ive had to do it and it still works fine
Status
asnes
