[ROM][July 23, 2012] AOKP Milestone 6 [RC5] AOKP/CM9 [Nightlies]
Status
Not open for further replies.
I got the second rc 2 to run...didn't do anything other than el26 kernel wipe and flash :D
Sent from my SPH-D710 using Tapatalk 2
Re: [ROM][July 15, 2012] AOKP Milestone 6 RC2
Gonna have to wait on that reupload....got work nice and early....really enjoying your roms tho man...thanks...posted a screen shot....if it helps
Reactions: Dark_Knight2
What's improved in rc2? What does RC stand for? I'm young. I'm a noob. But I'm learning :D
Sent from my piece of expensive plastic and silicon.
Rc stands for release candidate. New stuff like cm9 or aokp usually does this. Alpha then beta then release candidate then rls which is release. Usually by beta there are only a few bugs. Then by rc there are very few.
sent from my BAD A$$ Epic touch
Thats it in a nut shell :D
Reactions: patrao_n
This flashed for me with no problems with CWM that was built from source for FF18. You might want to update that you can flash from CWM (ff18) in your OP.
Can't use camera without external sd. (RC1) Can you fix that please?
Status
aimalee
