[ROM][July 23, 2012] AOKP Milestone 6 [RC5] AOKP/CM9 [Nightlies]
Status
Not open for further replies.
Everything seems good. Runs smooth and clean except MMS doesn't work. I went to a stock ROM, update PRL and profile and MMS worked fined. Flashed back to this and its a no go.
For what its worth, it doesn't seem to be working on times_infinty's AOKP build either.
Sent from my SPH-D710 using Android Central Forums
Mine works fine sir.
Sent from my piece of expensive plastic and silicon.
Well then, any idea as to why mine doesn't work? I'm pretty savvy at fixing my own issues but I can't figure why it would woke one place and not the other especially if other people don't have the problem.
It works for my tester as well. Did you go thru android setup wizard at first flash?
Sent from my SPH-D710 using Tapatalk 2
Yep everytime
Maybe a bad DL? It worked when i was running rc1. Maybe try going into settings......applications.....mms.......clear app data and cache. Then go into recovery and wipe cache and dalvik.
Try charging your battery to 100% then calibrate the battery. Discharge to 5% then charge again to 100% without intruption. Should be much better.
I'll try that. In the meantime, here's a screenshot.
On a total side note, I'm getting really low scores on Quadrant.
Re: [ROM][July 12, 2012] AOKP Milestone 6 RC1
new g apps and inverted g app mod work well together...no issues, running fast and smooth
Re: [ROM][July 15, 2012] AOKP Milestone 6 RC2
Anywhere we can download the files with out having to create an account to download them?
Status
francomattia
