[ROM][July 23, 2012] AOKP Milestone 6 [RC5] AOKP/CM9 [Nightlies]
Status
Not open for further replies.
Re: [ROM][July 15, 2012] AOKP Milestone 6 RC2
My installation failed...assert failed, status 7. Error in /emmc/AOKP_ET4G_Milestone_6_RC1.zip.
Downloaded three times and installed. Assert failed. Status 7. Help please.
EDIT: No ROM will install on this phone. I just received it from Sprint. (Status 7) Assert Failed.
You dont have cwm recovery. You need a custom recovery.
Sent from my SPH-D710 using Tapatalk 2
What are the benefits of this over your liquid ice rom?
Did you modify your build.prop at all? The updater script uses an assert command to gather build.prop info. It will abort the install if the assert command isnt processed.
No edit. I can't even get my own rom to flash. >:\
Status
francomattia
