[ROM] Not fully Official CM7 for Thunderbolt. 7.1.1 Updated 10-2
Lmao, soon as I posted that I checked to make a call and out of service error again. I'm just gonna stick to the de bloated stock gb Rom I'm running that I got from adrynalyne. I have to have a fully functional Rom.
Damn shame cuz cm7 was zooming on my bolt too
This is a shame. I have been using this ROM for a couple months now and have not looked back. The speed is incredible and the battery life is the best I have experienced.
There have been 2 updates since you posted about the problems you were having. I would encourage you to download 7.1.1, do a full wipe and give it another shot. You will be happy you did if you can get it to run smoothly on your bolt!
Re: [ROM] CM7 for Thunderbolt. 7.1 Updated 10-1 2:47PM EST Specia
Has anyone else had the call issues I'm having? Is the first post updated with the new file
Re: [ROM] Not fully Official CM7 for Thunderbolt. 7.1.1 Updated 1
This isn't my first Rom that's why I'm confused about the text and calls. I did full wipe, cache, davlik, and data. Flashed gapps then the cm7 zip. Then the gapps again to make sure it went thru.
I'm on a gb radio 148.00.0906w. The rom is working very fast but I cannot text or call, my data is rock solid fast on lte. Hopefully this is the info you need to maybe help.
The Rom is super fast id love to use it daily
Where is your second radio??? 1.48.00.0906w_1 is ONE radio... the second should be 0.01.78.0906w_2
Yes that is the second one, don't know how I left out the second one when I posted that.
Where is the 7.1.1 file? I went to the original link it shows 7.1.1 but when I go to it, it says the file has been removed or never existed
I just went to the first post, clicked on the link and it popped up RootzWiki's CM7 page... I clicked on the link and it worked.
Lmao this is nothing but trouble, what link did you click on I just tried again and got the sane message about the file being removed
Now its downloading,before it just showed that error message. Here we go again, I really hope it works this time, I gotta make calls and texts. I'll let you know after I flash it.
What kernel are you using for the good battery life?
Moving it to the sd card root right now, let's see if I can call out. Be back in a couple minutes
Well so far so good. I've been able to call and text, let's see if it makes it all day or not. What battery app do you guys use? I heard someone mention a governor but can't remember which one.
I use 2x battery from the market and it works wonders. I just use the kernel that comes with the rom. Seems to work just fine for me. Also, very glad to see that you are up and running now. You will see that it was well worth the effort.
Started the same stuff again. I'm so irritated now. I flashed the shiftao5p hack3d Rom and everything has been working great since 4pm. I don't get this at all, its basically the same thing with a few changes and I havent had a issue yet. Idk why my bolt doesn't like that Rom at all.
downloaded and flashed 7.1.1 through Rom Manager, wiped dalvik and cashe. I love this rom, I have been using it since RC1.4 and havent looked back. Although I did experiment with some sense roms and couldnt get back into that... What can I say, I like android the way it was meant to be :-)
just flashed this ROM, and I LOVE IT. Speed is fast fast fast :cool:
My phone can't find any weather locations. The CM7.1.1 page says to "Find New Netowrklocation.apk from latest OTA". Where can I find that? I scrolled through a couple pages worth of posts on the Rootzwiki page and gave up out of frustration. Thanks.
I just flashed CM7.1.1 for the first time and I'm really liking its flexibility and lack of bloatware, but it does not seem noticeably faster than stock. Where are you guys seeing noticeable performance improvements?
overclock the CPU!
Thanks, I was considering that but I read that SetCPU does not play nicely with CM's built-in CPU clock management. Is there a better way to do it than SetCPU?
joshchild106
