ARCHIVED: [ROM] Opti-ROM v1.1 built-in apps2sd, storage management, OCable!
Status
Not open for further replies.
Re: [ROM] Opti-ROM
So the dictionary isnt working? But the market version is working fine eh?
Sounds like Ima be themin another keyboard.... Thanks for the info tho, needed to know that. Its working fine for me... idk why.
Re: [ROM] Opti-ROM
yes that was on the list for next release, which sounds like it will be soon since the dictionary isnt working on the keyboard. That will all change soon. This is a first release to get all the input and bugs out.
Re: [ROM] Opti-ROM
The keyboard having dic. issues is a bug from LG that WE will fix.
^try restoring your apps manually and you shouldn't run out of room.
Reactions: hamagc
Re: [ROM] Opti-ROM
Right now what works is the app that we have included. If it isn't working, make sure you followed the instructions properly.
Sorry think you mis-understood the ROM is working great, it was just that some of my devices wont allow adhoc connections. Which is why I was trying to get something that allows infrastructure mode on the tethering working.
Re: [ROM] Opti-ROM
this rom needs more app storage. i can't even install a lot of the essentials. and yes i cleared everything as per your instructions.
What exactly are you trying to install? Encyclopedia Britannica? I never har more than 3 or 4 apps installed...
Sent from my Carrier Pigeon using Tapatalk.
Re: [ROM] Opti-ROM
You should start with a internal free amount of 110+ and the next update there should be the max amount of free space of 160. Try moving sum apps to sdcard go to settings>applications and move some for now to get a little extra space.
Re: [ROM] Opti-ROM
I've seen people mention that they only have like 4 apps installed before, and I always wonder, is that just exaggeration, or do they really not install any more than that?
Just off the top of my head, I know I have the following:
Titanium
aCar
Amazon
Amazon Kindle
Amazon MP3
Appstore
Craigslist
Convertr
Dolphin Mini
Engadget
ezPDF
ESPN Fantasy
Fandango
FriendCaster
ING Direct
Giantbomb
IMDB
K9
Mint
My Coffee
NetQ
Out of Milk
Seek Droid
Voice
Swiftkey
Xfinity
and all but maybe a couple of those are used daily. Weird.
Re: [ROM] Opti-ROM
see... I have a computer. So i dont have any need for all those apps. Also, I make backups of the apps and keep them on my SD card, so if I DO need them, I can use them. And yes.. honestly, I AM one of those people that says they only install a few apps, and I do! Even on my EVO 3D, TONS of space but its just that.. tons of space that im not using. :cool:
Re: [ROM] Opti-ROM
whats the point of a smartphone without apps? i run a bunch of stuff and have had plenty of room on every rom until this one.
Re: [ROM] Opti-ROM
it seems that wiping the dalvik after the initial install cleared a about 50meg
Re: [ROM] Opti-ROM
Im just that way. I dont like the clutter. Always have a clean homescreen and all of them are basically empty. I only use what I need. I will check out the new apps but other than that I just delete them unless I need them. I guess im not American since I dont NEED NEED NEED everything. :p
Re: [ROM] Opti-ROM
LMFAO! Ok, you are alright in my book. Anyone willing to talk junk on Cr-apple is ok in my book... well til u really piss me off ;)
Re: [ROM] Opti-ROM
Can someone post the stock GB kernel for this ROM? I had gROM up and running and finally found a work-around for infrastructure-based Hotspot using the WiFi tether 3.1beta 6 app since the Hotspot doesn't seem to work yet on these GB roms.
Installed this ROM and been running great, but can't get wifi tether to work properly. Reading a few others forums, seems some guy had luck on a different platform switching back to a stock ROM vs. modded, so was hoping to do the same to see if there's some other hook that drew's ROM is missing that dis-allows wifi tether to create the hotspot.
Status
rob805213
