ARCHIVED: [ROM] Opti-ROM v1.1 built-in apps2sd, storage management, OCable!
Status
Not open for further replies.
Re: [ROM] Opti-ROM
Is VVM included and working in this ROM? Also how about the bugs of the browser scrolling and the battery uptime? Thanks!
Re: [ROM] Opti-ROM
Sprint VVM is included. I don't personally use it, but it seems to be working. :) I haven't experienced any bugs since upgrading to Gingerbread. No lag, slowness, etc that everyone else is reporting. Just make sure to wipe everything properly as the instructions list it! :D
Reactions: memsman
Am I able to use data2ext with this rom or is it a feature needing to be added
Sent from my LG-LS670 using Tapatalk
Re: [ROM] Opti-ROM
As long as you format your ext partition as ext2 or ext3 I think it should work no problem. I am currently testing a new version of GingerKernel which supports ext4 and the Smartass2/InteractiveX CPU governors as well.
Reactions: basketthis
Re: [ROM] Opti-ROM
Can we use the previous app2ext zip file that was floating around for CM7 for this? Or does it require a new set of instructions to enable?
By the way, it took a LONG time for this to boot first time - turns out that it was because data isn't required to be wiped (according to the directions, so I didn't), and because I was coming from gRom which has dalvik cache moved, I was out of storage space and it put me into a wizard to remove/move apps before I could continue. I removed netflix and was good to go. Looking forward to playing around with ext options later tonight!
Re: [ROM] Opti-ROM
Umm, it says to in step 4
Wipe: system, cache, data, dalvik cache (everything)
Re: [ROM] Opti-ROM
think you can remove or replace the android keyboard with the gingberbread keyboard from the market? (so word suggestion works) ? Otherwise so far so good :)
Re: [ROM] Opti-ROM
Word suggestion works. The keyboard with the large dictionary is already included. ;)
Re: [ROM] Opti-ROM
hmm wondering why it didnt work for me, gonna reboot, try again, then if not, reflash...
Edit: word prediction still isnt working for me (contacts only)
i know
Gonna wait and see how this develops. App. space was too small.
Re: [ROM] Opti-ROM
i know
Weird. Have you tried wiping everything or doing a dirty flash? That was the first thing i did was replace that stock keyboard! Lol.
Re: [ROM] Opti-ROM
Thanks for the ROM. So far i haven't been able to get VVM to work. I deactivated voice mail forwarding, updated profile and sent a message to activate@vvm.sprint.com (with 2 v's). Still no luck.
Status
Dreamz
