[ROM][Sprint][JB][08/25/2012] Jellybro CM10 [Nightlies]
Status
Not open for further replies.
I went from 100% to 15% battery life in just a little over 3 hours use and I didn't have any apps running in the background either. Wish I could get better battery life than this, I am also using Sbrissens Newest JB Kernel on CM10 Nightly 2
Is the screen shot taken right when you experienced los? That seems to be the big killer, is losing signal and then not noticing. When the phone tries to keep finding signal it eats the battery up. Granted that is part of the kernel and not really your fault but just kind of a heads up. If you can catch it. Just reboot your phone and your battery might last a little longer.
Sent from my SPH-D710 using Android Central Forums
Re: [ROM][08/14/2012] Jellybro Euroskank CM10 [Nightly 2]
Like the guy before me said, prolly got crushed during LoS. Use the attached file from HERE and it should help you out. It helps me out a decent amount!
Love he rom hate the battery keep it up ! Can't wait for whats to come of this :D!!
Does anybody have any suggestions on which kernel would be the best to use?
That's what happened to me. I just went back to nightly 1 then flashed the latest kernel. No los so far and I'm at 17% after going from 7:30am to 9:15pm with 15 min of charging during that period. Medium-light use.
More epic battery life and only at 63%.
4 hours on battery so far
Loving nightly 2
Sent from my SPH-D710 using Tapatalk 2
Odd, I found that while charging the battery was actually draining faster than it was charging.
SMH..... _Viper_ There is a direct link to the tasker los thread on xda in my op that has detailed direction on how to use it. It is NOT cwm flashable.
I followed that link but it took me to the LoS Repair Daemon thread. I didn't read anywhere in that thread about Tasker plus it has its own flashable that for all intents and purposes sounds like it is similar to what Tasker is supposed to do. However, no one that has tried that flashable on JB has had any success. I will go back and read it again tho. Sorry for the wasted space in the thread buddy!
Edit: I found the instructions in PhantomPhraek's thread. Bout to reflash the rom and try it out.
Sent from my SPH-D710 using Xparent SkyBlue Tapatalk 2
Plugged into the wall, or a computer? Mine does the same thing when plugged into a comp, but that is normal (I'm on cm9).
anybody that is having problems flashing Sbrissens JB Kernel Odin CWM6 it would not flash for me in mobile odin so i just unzipped it and copied it over to my sd card and moblie odin the boot.img and ran fine.
also i have had LOS like crazy on FF18 modem. i flashed FG31 and have had not 1 LOS i know everyone might not net the same result but im just throwing this out to help :)
When did you flash the FG31 Modem?
44% battery left and 12 hours on battery so far :thumbup:
another question why is there no way to update PRL or Profile ? is it just a CM thing ?
Status
