[ROM][Sprint][JB][08/25/2012] Jellybro CM10 [Nightlies]
Status
Not open for further replies.
What modem are you using how is LOS? did you flash the port then let sit for while?
I'm using the stock fg31 the port comes with. I get los once every 5 hours or so for a few sec but it catches itself within 10 sec. I flashed, skipped registration, rebooted, then registered/ restored apps via recovery with app2zip app. Let the battery die (never charged it). Took out he battery for 5min. Plugged in and let it charge to 100% then turned on phone.
Sent from my SPH-D710 using Tapatalk 2
My rom does not come with the FG31 modem? I never added a modem to this rom EVER :confused:
Re: [ROM][JB][08/14/2012] Jellybro Euroskank CM10 [Nightly 2]
OK I will try these steps and that fg31modem
Sorry I did flash the modem my mistake m memory isn't so good my vacation started yesterday lol :beer::beer::beer::thumbup:
Any ideas on how to get vm indicator to go away?
Plus everytime someone leaves me a vm i get 2 texts from 9016
//ANDROID 3165555555 has sent you a Sprint voice Message Cal 408-970-0000 to listen
mmsn c33213es1sd321d
How do i get this to stop?
well this is strange i only get LOS while charging ! figure that one out!!!:mad:
I would recommend switching to google voice and just not going with the sprint integration. That would probably fix your problem until they get sprint vvm working.
Reactions: hevenz1
There is a new Modem in the block. It is FH13. May be we should check this one out. I'm at work now, so I'll download everything and then flash when I get home. I'll report later on the state of the LoS...
It will be cool to test once they release it. Its still just a kernel though. They haven't released just the modem.
EDIT: I stand corrected they just released it.
well i have noticed every time my phone sleeps then i wake it up to send text or make a call even if i force it to sleep im getting LOS
does not matter what modem im running atleast for me
weird last night it was fine
:p
44% battery left and 12 hours on battery so far :thumbup:
Click to view quoted image
Your phone has spent 9.5 hours in deep sleep. No wonder your getting such long battery times. You have to use it realistically, otherwise people think that there is something wrong with their phone when the tester gets 24 hours of battery.
Sent from my SPH-D710 using Android Central Forums
Reactions: ahmadshawki
I did I was using it a lot watching YouTube vids, playing MP3s, posting on forums, browsing web. went to bed woke up kept using it etc. To me thats realistic..
That explains why it was in deep sleep for 9.5 hours. Overnight. But you only used it for 2.5 hours according to the math.
Hmmm... might have to try that then... This wouldnt fix the stuck vm indicator on top would it?
Possibly. Did you install sprint vvm? if you have the sprint voicemail app on there. I would remove that. Just make sure if you switch to google voice to skip the first step, otherwise it will try and integrate your vms and text messaging and not work right with your default messaging app.
Status
animats
