[ROM][Sprint][JB][08/25/2012] Jellybro CM10 [Nightlies]
Status
Not open for further replies.
Re: [ROM][JB][08/21/2012] Jellybro CM10 [Nightly 4]
Are people having rotation issues all with US Cellular phones?
No just like 2 are. Nothingblooms hasnt had rotation issues at all. Hes on US Cellular
Getting ready to flash this now I too am on USCC will post back with my findings. Nightly 2 is where I am currently with no rotation issues to report.
I wish it was that easy. Rotation is still off, and no wifi:-\
I don't know what to tell you man. If your following the op there should be no problems. No one else is having any issues. You could go to dk's ICS rom and try that out.
Sent from my SPH-D710 using Android Central Forums
I'm on your AOKP stable 4 and i tried to odin Sbrissen's JB kernel and I get a message saying Complete(Write) operation failed. I tried extracting but the boot image doesn't show up. Any idea what i can do?
Thanks for your awesome work!:)
Battery life improves with each release, somehow, it keeps getting better :). If an official JB build for this phone was ever released, it wouldn't be half as good as this rom.
DK this should be a FAQ
Just pull the boot.IMG from that file and save it to your SD card. Then open Mobil Odin and flash the boot.IMG
DK N3/Lowrider Gapps/FH13
Wiped as per OP & phone is stuck in landscape mode. Using Nova Launcher and changed settings to auto rotate & did the same in system settings with no change.
Status
weaversweb
